HELP TRANNY is doing WEIRD things
Last weekend I dropped the pan and tightened the Bands..I had no torque wrench so I just tightened to hand tight and then backed off 2 turns...everything feels good except 3rd gear...NOW when it shifts into 3rd the RPM's will jump about 200 rpm then falls into gear?? thats under light throttle...if I give it more throttle it will rev higher before falling into gear..I also switched to RED LINE synthetic fluid...did I tighten the bands to tight?? ANY IDEAS.........thanks..its an A518.
The front band is for second gear and rear for reverse so not the band. Fluid level all topped up, running in neutral.... ? Did it shift fine before? It might be the different fluid?
Adjusting the band might just change the time that it takes to come out of second, only other thing that comes to mind. Does it have a shift kit?
lMy thought is band too loose. This allows band to release before front clutch is close to locking up, hence a flare on upshift. Heavy throttle and fluid pressure compensates to get timing closer on release/apply.
oldsmokey97
May 16, 2008 08:44 AM
oldblu
Mar 27, 2007 10:29 PM
MustangHauler
May 4, 2006 07:39 PM
