help me quick!!!
Old Apr 10, 2009 | 11:47 PM
bigbaddiesel416's Avatar
From: anderson commiefornia oh ya you can keep the "change"
Angry help me quick!!!
i have a race to go to tomarrow and iam leaking oil from the pan i got the engine jacked up the tranny up as high as they will go and i still need a 1/2 in to clear the cross-member how do i get it out
TIA
brice
Old Apr 11, 2009 | 09:31 AM
justinsdad's Avatar
I think you either have to pull the motor or cut out the crossmember and re-weld it back in.
Old Apr 11, 2009 | 09:52 AM
jeepsuck's Avatar
how bad does it leak? can you not race with a leaky pan?
Old Apr 11, 2009 | 09:54 AM
92 Bob's Avatar
torch the rivets on the crossmember, take it out, when your done bolt it back in.
Old Apr 11, 2009 | 09:58 AM
jeepsuck's Avatar
it requires a substantial amount of weld cutting on the cross member as well. you could not do it with the engine in the bay which makes removing the cross member a moot point, not to mention the time involved in completely dismantling your front suspension and the brake lines that run in between the cross member pieces. i would suggest removing the transmission and lifting the engine higher, be VERY careful when working on the suspended engine. i would want some sort of fail safe in addition to the cherry picker.
Old Apr 11, 2009 | 10:03 AM
Your pan may have rotted.
Old Apr 11, 2009 | 11:04 AM
it leaks bad i pulled it to find a washer and cant get it backup and stop leaking i replaced the gasket once and silicone still leaks
and it leaks REALY bad and leak = no race
Old Apr 11, 2009 | 02:40 PM
Tron's Avatar
i pulled one on a 98 5.9l and removed the oil pickup when the pan was loose. I already had the motor jacked up, with the pickup gone I was able to slide the oil pan out. Not sure if this works for you though.
Old Apr 12, 2009 | 02:50 AM
i got it it was a ***** tho i never could get it out so i cut the gasket fed it around lots of silicone and 8 hours later no leaks and i kicked *** at my race
Old Apr 12, 2009 | 02:56 AM
93-12Smoke's Avatar
If you only need about 1/2 in, removing the motor and trans mounts should get you that with a motor lift and a floor jack on the tranny.
Old Apr 12, 2009 | 03:00 AM
i had the motor up as high as it would go and the trans and still needed a
1/2in
Old Apr 12, 2009 | 11:31 AM
smoking's Avatar
What times did you get at the track??
Old Apr 12, 2009 | 12:13 PM
i was running 1/2 throttle @ a 15.8 my buddie has a 07 megacab that likes to get smoked so i cant beat him too bad other wise he will give up hes got Intake, exaust, 120 hp chip its a $62,000 rig and still gets by my $1,200 pos every time we race he goes out to buy more **** to beet me and i guess i should tell him thar i can run 13.2 he thinks i run a 15 flat oh thats the racers rule (when they ask "what you got in there")(you tell them more than i need)(and during a race only beat them by a car length or two)(the sleeper)
my best time was 13.2 a while back i need more air
Old Apr 12, 2009 | 03:16 PM
roxxx's Avatar
take your back valve cover off that gives you the room to lift the motor up
Old Apr 12, 2009 | 03:23 PM
JQmile's Avatar
Wait, you ran a 13.2 with a 5 spd?
