Hello All
Old Jan 15, 2018 | 04:05 PM
ehartzell's Avatar
Hello All 1991 W250 Cummins
Hello all, New Gen 1 owner here, First off, please forgive my lack of knowledge. I have 1991 W250 LE 5.9 Cummins, with an automatic transmission I purchased a few days ago. already have a few issues taken care of. As of rigt now the only things that do not operate correctly are the speedometer (odometer works), cruise control, and the overdrive. Ive read a few post and started tracking down the issue which i believe are all connected. Replaced the the VSS which did not correct the problems. Im wandering if anyone had experienced the same and where they started. Could the problem be related to the fuseable links?
Regards,
Eric
Old Jan 15, 2018 | 04:13 PM
edwinsmith's Avatar
Regards,
Eric
Welcome to the group. If you wouldn't mind put your truck year etc... in your signature then it gets posted along with all of your posts. We have lots of knowledge and practical experience and are ready and willing to help.
Edwin
Old Jan 15, 2018 | 05:59 PM
Hi Eric
Welcome to DTR.
THE 91.5 IS a bit of a different animal than my 92, as so I've read a bazillion times over the years , here, on the boards.
My truck had the same issues you have, and yes, in my case, it was one of the fusable links. Not sure with yours. I'm sure J. or Alec or one of the other proficient electrical guys can help. Have you tried switching the relays around as in the Sticky? The group of 3 relays on the engine firewall behind the battery, in front of the hinge driver side . one of the relays controls the functions you're not getting. Again, 91.5 might be different, so I'm just throwing that out there. My 92 had the fusable link burn through without visual change. I only found it by testing continuity, after testing / swapping relays first. I temporarily spliced it together, but eventually replaced all fusable links with fuses
Thanks for spelling Cummins and not Cummings. Pretty sure she is an adult film star.
Old Jan 15, 2018 | 06:42 PM
ehartzell's Avatar
T, thanks man. My next project is to replace the interlocks with fuses, well actually gonna have a friend of mine do it.
Eric
Old Jan 16, 2018 | 10:17 AM
N. Besonderes's Avatar
10 Year Member
I had a '91.5 D-150 gasser which had a working odometer but no speedo.
I pulled the gauge and tested it by pulsing it with 12 volts. Nothing.
Once the electronic speedometer in my '93 finally craps out, I plan to just swap in a cable-driven unit that I have from out of an '86 RC.
Which part of this Great Republic of Texas is home to you?
-Niemand
Old Jan 17, 2018 | 06:31 PM
ehartzell's Avatar
Niemand, I hale from just west of Fort Worth.
Eric
Old Jan 17, 2018 | 08:46 PM
10 Year Member
Roger that. I'm just a short stretch down I-35 from you here in Williamson County.
Glad to have you aboard.
-Niemand
BigBLu
Feb 16, 2007 06:36 PM
Huntsalot
15
Jan 9, 2007 04:07 PM
DynoJoe
Jul 14, 2006 07:01 PM
calls
Apr 23, 2004 09:03 PM
bwuest
Apr 5, 2004 02:52 AM
