heater install
heater install
where does the coolant come out of the motor to go to the heater core in an 89 d250 with the cummins because mine doesn't have any thing ac\heat related so i'm installing a heater but need to know where the coolant comes from and returns back to the motor through a new heater core
im not going to hook it back up to the heater core because i dont have a blower motor in my truck but summit makes this heater with a blower built in on it that you just hook up like the heater core then plumb to the vents and its just the same.
I would test what you have first and see if you even have a problem.
If there was a problem I would re-use OEM style parts, not Summit's universal kit...Read Mickey Mouse kit most likely.
OEM parts will fit like they where engineered for your rig. The other stuff will end up being a hacked together job.
rjm022
Dec 11, 2019 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
