Heater control valve
Old Nov 22, 2009 | 11:43 AM
Lightweight's Avatar
Hi Folks,
I want to put a ball valve in the heater hose, for improved a/c???, next summer.
The inlet to the heater core or pressure side is the valve?
Thanks
GW
Old Nov 22, 2009 | 01:07 PM
ppiggppenn's Avatar
I don't think it matters too much which hose you use as long as you stop coolant flow to the exchanger, just grab the one more convenient for controlling the shut-off, ...
Old Nov 22, 2009 | 02:18 PM
Jim Lane's Avatar
Post
This is where the water valve is located from the factory on my 1991 D-350, it is on the left.
This will make your air a lot cooler inside the cab, now you will not be having to cool down 140* incoming air with your evaporator.
From my post,
https://www.dieseltruckresource.com/...d.php?t=209772
Jim
Old Nov 22, 2009 | 04:10 PM
Thanks Guys,
That is what I thought.
Mr. Lane, my 92 is set up the same as your's.
WEll it will be tomorrow, anyway.
GW
wmbthe4
May 8, 2011 12:19 PM
Boatnik
Dec 24, 2006 07:44 PM
broncobilly
Oct 27, 2006 12:05 AM
