Headlight Switch
Though I don't have an older Dodge, I've used a headlight switch for my even older Jeep from Rockauto.com, and it's still holding up fine. I used one from Autozone once, and it didn't last more than 2 years if I recall. In fact, I've used a lot of parts from Rockauto.com, and I haven't had any negative results yet. I know other guys order parts from them too.
Not sure if this link will work, but I'll try:
http://www.rockauto.com/catalog/x,ca...,parttype,4472
I think your headlight switch is a 4565 320:
Does not include shipping: https://www.dodgeparts.com/oe_parts_...9a2a8fedef9bdd
Includes shipping over $50: http://www.trademotion.com/partlocat...?siteid=213794
I've never had a problem with a headlight switch from NAPA.
What was wrong with the old one? Putting the headlights on relays is a good way to lessen the load carried by the factory undersized wires and ease the load on the switch.
I have been told that the aftermarket switched don't hold up nearly as good as the factory ones. That being said though, my NAPA replacement has been working flawlessly for over a year now.
If you were to install relays for your headlamps and running lamps there would be only a minimal current passed through the switch and it could very well be the last switch you will ever replace.
Not sure which country the aftermarket switches are made in but I have an Ignition switch from NAPA that is about 3 years old and is still working fine.
Jim
Jim
mtdoragary
Nov 7, 2013 08:31 AM
jesse123
Jul 8, 2012 09:04 PM
Barryn
Jul 14, 2008 09:30 AM
jlipskoc
Oct 24, 2005 01:16 PM
2nGlenn
Mar 11, 2003 01:51 PM
