Headlight Plight
Old Jan 9, 2009 | 06:58 AM
Rafter B's Avatar
Headlight Plight
My 89 has low beam headlights only. When I click the multifunction lever on the column I either get lowbeams or darkness. Is it the multifunction or something else? Thanx!
Old Jan 9, 2009 | 08:12 AM
cootz's Avatar
My guess is that your highbeam element in the headlight is blown. Can happen after voltage regulator issues or a voltage surge when your high beams were on. Time for a new set of headlights (go for the Silverstar Ultras).
Old Jan 9, 2009 | 09:39 AM
RowJ's Avatar
Originally Posted by cootz
... Time for a new set of headlights (go for the Silverstar Ultras).
Good advise. Love mine. Big improvement ..... and the factory 02's are a lot brighter than your, I think!
RJ
Old Jan 9, 2009 | 10:53 AM
np205's Avatar
The hella's are nice and bright. Replaceable bulbs now instead of replacing everything.
Old Jan 9, 2009 | 02:23 PM
Rafter B's Avatar
Are the silver star ultras helas or not? Where do I find them?
Old Jan 9, 2009 | 02:28 PM
RowJ's Avatar
Silver Stars Ultras are at all O'Reillys Auto Parts..... if you have those.
Silver Star bulbs made by Sylvania...not Hela
RJ
Old Jan 9, 2009 | 06:00 PM
BearKiller's Avatar
Take a HOT jumper-wire and put it to the hi-beam prong on the headlight; lights up = bulb okay, no light = bad bulb and problem found.
Otherwise, the dimmer-switch is probably bad.
Best is to buy a generic floor-mounted dimmer, screw it conveniently to the floor, and route the light wires through it, just eliminating that mess on the column.
Old Jan 10, 2009 | 07:42 PM
Rafter B's Avatar
Got the Silver Star Ultras at Oreillys today. Both hi and lo works now and they are brighter. Thanx Again!
mtdoragary
Nov 7, 2013 08:31 AM
jlipskoc
Oct 24, 2005 01:16 PM
2nGlenn
Mar 11, 2003 01:51 PM
bdog
Nov 23, 2002 09:36 PM
DeaconWayne
Oct 10, 2002 07:23 AM
