Head Gasket Advice
Old Jul 22, 2016 | 07:40 PM
bannerd's Avatar
Head Gasket Advice
Hey all,
Started to take apart the 4bt for the ramcharger project. It needs a head gasket, do you guys coat these with anything? How is that copper spray? It looks like the gasket failed because of the rubber compound.
On a side not, the Case 207D engine starting puffing white smoke.. which needs a head gasket as well. Sleeves tested out fine..
Let me know, I'll go pick up some stuff saturday.
Old Jul 28, 2016 | 09:27 AM
ofelas's Avatar
Hi,
Install dry.
Old Jul 29, 2016 | 12:59 AM
DodgeFreak's Avatar
Don't put anything on it. Also on the 207, It might be worth your time to pull it completely apart and go through it. I've had where the head has been removed and it disturbed the orings on the sleeves enough that they ended up leaking and dumping coolant into the water not on the 207 it was other sleeved engines as I'm not up on the 207 as I am with the 148 gasser, and the bigger 6cyl Case's
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
