head gasket
Old Apr 5, 2010 | 10:35 PM
willy wagon's Avatar
head gasket
looks like the head gasket is starting to leak next to the thermostat housing. only 240 ks on the engine is that normal? what causes this problem?
Old Apr 5, 2010 | 11:02 PM
dieseldawg604's Avatar
what year ? any mods?? how much boost are you running???
Old Apr 5, 2010 | 11:20 PM
jimbo486's Avatar
maybe worth a shot to replace the thermostat and seal. see if that takes care of it. start with the cheapest possibilities first.
Old Apr 5, 2010 | 11:47 PM
93flatbed's Avatar
I wouldn't go as far as saying "normal" but that's right about the miles and same place as both of mine. Sorry to tell you, but as jimbo said make sure the t-stat isn't the problem first.
Old Apr 6, 2010 | 07:41 AM
CaptainChrysler's Avatar
Mine let go at 243k. The gasket basically rotted out.
Old Apr 6, 2010 | 10:19 AM
92smokin blacky's Avatar
uh oh... I guess i better be watchin mine, i've got 243k on mine now and its seen 40 lbs a few times...
Old Apr 6, 2010 | 11:16 AM
dzl_damon's Avatar
I think I remember hearing the non IC's go quicker. Mine possibly only has 75k miles and it's seeping off the driver side
Old Apr 8, 2010 | 11:05 PM
big stinky's Avatar
Yep, non i/c gaskets rot out... Mine went at ~300k kms...
Old Apr 8, 2010 | 11:26 PM
dzl_damon's Avatar
rot as in from time or mileage you think? Not from overboosting? I'm pretty sure my miles are low, and the truck has been stock it's whole life except the last 3,000miles.
It would at least make me feel better if I knew I didn't cause it!
Old Apr 9, 2010 | 06:56 AM
Rot as in old age, it just deteriorates. I think I did mine in from reving it up too hard before the thermostat opened. There was only like 1/16" worth of gasket left sealing it, so it was only a matter of time anyways. The new gaskets from Cummins are upgraded in that corner.
If it is leaking right below the thermostat, it is probably not boost related, IMO.
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
blueberry
Feb 7, 2007 05:34 PM
Conn
Dec 29, 2006 06:30 AM
MADSEN
Oct 7, 2004 09:43 PM
