Having trouble finding a lift pump
Old Nov 8, 2010 | 01:18 PM
12valvin's Avatar
Ok the answer to this question might be burried somewhere in a thread but does anybody have the part number to the low pressure piston lift pump?
The one that does not need a regulator. My cummins dealer around here is a joke and there parts department is even worse.
Is there a pump where you dont have too grind some of the block away?
Old Nov 8, 2010 | 01:25 PM
Onemoparnut's Avatar
Have a look in the sticky.
Old Nov 8, 2010 | 03:01 PM
I got mine from Oregon Fuel Injection....Delphi pump and the spacer and 2 gaskets for $84...I would definitely recommend.
It's not on their On-line catalog, but if you call they can get you set up.
Old Nov 8, 2010 | 03:46 PM
steve5.978's Avatar
lift pump
go to your local case ih dealer part # 87473338 is the pump 208.99 the trator uses a spacer part #j914284 dont know if this will get you away from the grinding I have used the standard pump on my 92 dodge it bolted right in at small fraction of the price 47.00 #84142216
Steve
Old Nov 8, 2010 | 08:26 PM
roccoboost's Avatar
Did this a while back
Cummins numbers: lift pump- 4988751
spacer gasket (2)- 3939258
spacer- 3914284
Old Nov 9, 2010 | 07:14 AM
KD93's Avatar
Wow, good price!!!!
Old Nov 9, 2010 | 11:12 AM
Originally Posted by KD93
Wow, good price!!!!
Yeah I thought so too!!! It was a member here on the DTR that mentioned it.
Old Nov 9, 2010 | 07:25 PM
ClassA4x4's Avatar
Do you have the Delphi part#?
mknittle
Feb 16, 2015 08:03 PM
12valvin
Jan 8, 2012 07:55 AM
Varmint
19
May 1, 2010 09:50 PM
Bonehead4444
Aug 13, 2009 09:29 PM
PeytonMaterne
Jun 24, 2009 08:20 AM
