H2E swap
Old Jan 28, 2009 | 10:44 PM
Ramrod90's Avatar
H2E swap
I just came across an H2E with a 64 mm charger and I was wondering if that would be too much air for my setup. the only thing I have thats not in my sig are New Era 6x18's. I need all the pro's and cons as well as capabilities of this turbo/upgrade.
Old Jan 28, 2009 | 11:25 PM
Ramrod90's Avatar
As far as adapting is concerned, will it fit on my exh. manifold. and 4" DP? What do I need to do to put this trbo on my truck? Thanks.
Old Jan 29, 2009 | 07:21 AM
RSWORDS's Avatar
What size exhaust housing does it have? also what flange? t3 or t4?
Old Jan 29, 2009 | 09:56 AM
apwatson50's Avatar
Sounds like a t4 based exhaust housing, probably like a 23-26 cm something like that?
I don't think your going to like that, probably won't spool till like 3000rpms. haha
if you found a t3 based 16cm exhaust housing it would be great!
Aaron
Old Jan 29, 2009 | 11:58 AM
Is that like a 64/71 ?? a 16cm would spool slow on that thing, i think if you buy like a 64/71 phatshaft the biggest exh. housing they offer is a 14cm.
You'd have to try to find a 14cm housing, which would be $$$ and hard to find.
You definely have enough fuel for a turbo that big though. 6x18's FTW
Old Jan 29, 2009 | 06:09 PM
Ramrod90's Avatar
So far all the guy told me is that it is a 64mm compressor and I haven't got a reply as far as the rest of the specs. with the amount of fuel i'm putting in my H1C is having a hard time keeping up so I figured this turbo would be ok since I only have to spool it once (auto). plus, if it works I will still have plenty of air left over for more fuel mods like Air Dog or larger lines and that sort of thing. A 16 cm exh. housing requires a 4" DP doesn't it? Last Question is... do they make an adapter for T3 to T4 if the turbo is the wrong one???
Old Jan 29, 2009 | 06:30 PM
They make an adapter, the size of the exh. housing has nothing to do with exhaust outlets. the 16cm number is a measure ment of the inside of the exh.housing.
cummin2tkme
Dec 31, 2003 08:50 PM
Hawkeye
Sep 23, 2003 08:22 PM
cummins24
Apr 13, 2003 10:06 AM
C4L
Feb 13, 2003 03:43 PM
