Grid Heater Issues
Old Jan 4, 2011 | 09:09 PM
miningman's Avatar
Grid Heater Issues
1992 Cummins. Issue started last month at minus 20 Celcius, turning on key to initiate " wait to start cycle " and what I got was a very loud repeated clicking apparently coming from the relays that power the grid heaters.
So I thinks to myself " time to change the relays before it starts to get cold here" .. presently working in an area that will go to minus 32 or 35 , possibly even minus 40.
Changed out the relays and the problem seemed to be resloved ( but it has only been minus 10/12 lately) but two days ago, again at minus 22 , problem has re occured.
So before it gets cold here, what else do I look at??
Appears to be temperature related, and is almost certainly the relays I can hear...provided I can get the heaters working, she starts and runs fine in all other respects.
Old Jan 5, 2011 | 02:19 AM
Santaclaus's Avatar
The general cause for relates to chatter is low voltage. If your battery is good then it is most likely in the wiring someplace. Mike
Old Jan 7, 2011 | 09:18 PM
Usually a bad PCM. Sorry.
Old Jan 7, 2011 | 09:33 PM
JD730's Avatar
Yup, been there, done that, twice.
The relay that's chattering is not the grid relays, its a different one in the same area.
Old Jan 7, 2011 | 11:08 PM
miningman's Avatar
JD any chance you could identify the offending relay for me ???
Louie Bornstein
Jan 3, 2014 09:11 PM
pulltilbroke
Feb 24, 2011 05:07 PM
Ramrod90
Feb 3, 2009 07:39 AM
jrogers
Feb 18, 2008 04:19 PM
taildragger
Dec 4, 2006 10:00 AM
