getrag input shaft bearing
Old Feb 2, 2008 | 11:57 AM
win's Avatar
win
quick question. can you replace input shaft bearing without going into the transmission? thanks
Old Feb 2, 2008 | 12:10 PM
dpuckett's Avatar
No. All bearings are inside the case. Ifyou rinput bearing is bad, it isnt a bad idea to replace all the others while you're in there. A bearing and synchro kit on only $200-225.
Daniel
Old Feb 2, 2008 | 04:41 PM
12valve@heart's Avatar
If you don't have the Getrag portion of the factory service manual, PM me with your e-mail address and and I'll e-mail you the .pdf file. It gives you the breakdown as well as teardown and reassembly instructions. It's what I used to rebuild my Getrag.
Old Feb 4, 2008 | 10:10 AM
GLHS's Avatar
If you want a quick and temporary fix, you might be able to get by with a new pilot bushing. They are usually worn out if over 100,000 miles.
Old Feb 4, 2008 | 10:31 AM
Originally Posted by alsplace
I have a Getrag that I will probably have to rebuild in the near future. I have been looking for a manual on it.
Check your PMs
jcg
Jan 31, 2011 08:56 PM
RTillery
Oct 1, 2009 06:04 PM
larry104
May 19, 2009 05:45 PM
Kim8839
Jan 13, 2008 07:03 PM
feveree40
Jan 2, 2008 06:53 PM
