getrag
Old Aug 17, 2007 | 09:34 PM
  #31
Exekiel69's Avatar
Just to make something clear, is better to overfill and the quantity is 5qt right?
I think the elbow with clear plastic is a great idea, some say this trannys leak some so it is good to have a visual reading of how much really is in there right?
Also, what fluid to use 80-90w, sincromax, lucas anti slip and most important Where do I get it?
Thank You.
Old Aug 18, 2007 | 07:30 AM
  #32
Ace's Avatar
Ace
Yes, various ways they leak are often traceable as root causes to the failures they suffer. Whatever you do DO NOT put gear oil in it! A fresh fill of synchromesh or 5w-30 sythetic motor oil is all it needs. Synchromesh is best.
Old Aug 18, 2007 | 04:31 PM
  #33
Exekiel69's Avatar
Where could I get this fluid?
Thank You.
Old Aug 18, 2007 | 04:36 PM
  #34
Ace's Avatar
Ace
Checker had decent prices on the RP stuff last time I was in there.
Old Aug 18, 2007 | 07:05 PM
  #35
Exekiel69's Avatar
Not to get pushy but anyone else have this by chance? the closest store is over 500 miles away.
Old Aug 18, 2007 | 07:15 PM
  #36
Originally Posted by musicalrattle
Will overfilling the Getrag smooth out the shifting and enable faster shifting? Mine takes a bit of pull to change gears and going into 3rd definitely isn't smooth. Some may be my technique or lack thereof but shoot, it's not the smoothest shifting vehicle, and I've seen videos of people shifting fairly quickly on here. I can't do that with mine! If putting an elbow & extension tube on the fill hole, is there a good tube length to use above the elbow to have 1 additional quart be at the top of it?
Also, where does everyone's clutch engage? Mine is right at the top end, so you have to let it out a long way before engagement.
Hope this wasn't too much of a hijack , but it seemed like this was a general Getrag thread.
An overfill won't help with your issues. Some of 'em shift pretty nice, others (like mine) are really slow from 2nd to 3rd. Winding it up high in 2nd seems to help some.
Originally Posted by Exekiel69
Just to make something clear, is better to overfill and the quantity is 5qt right? .
No, 4.5 quarts is the correct amount.
Factory fill was 3.5 qt.
Summit Racing sells it. My trans is still a little balky when cold, but it is way better than it was with 5W-30 Mobil 1.
Old Aug 19, 2007 | 10:45 AM
  #37
Exekiel69's Avatar
Is this the one?
Old Aug 19, 2007 | 02:37 PM
  #38
You got it.
Old Aug 21, 2007 | 09:58 PM
  #39
dsm1's Avatar
Originally Posted by dsm1
Mainly noticable in 3rd and 4th when unloaded, just maintaining speed on flat road. If it starts to rattle I can apply more throttle or downshift and it will stop. Its been this way for a couple of yrs but seems to be worse now. OK when its cold. It's just annoying and a bit worrisome.
Also, I've noticed a "clink" of slack in the driveline when shifting. Not sure if it's a u-joint, diff or in the gearbox. I'll have a closer look this weekend when I do the fluid change.
What diff fluid is good for these old beast?
OK, Did the fluid change. Overfilled it 1qt with 5w-30 synthetic and its much quieter now. Gear changes feel a bit more positive.
Slack in the drivetrain turns out to be a combination of the center driveshaft spline joint and two U-joints. Just a very small amout in each adds up.
I replaced the front joint last yr. The rear two have no zerk nor does the spline joint. I may add a grease fitting to the spline when I do the
u-joints.
Old Aug 22, 2007 | 02:27 PM
  #40
Twelver's Avatar
Novice questions here, but what's the best way to get the oil into the trans...especially if I build the overfill tube arrangement in the sticky? What does everyone use, as the space to get a quart bottle at the right angle to fill is tight? Does everyone just use thier 1/2" drive ratchet to loosen these, or do you have a square drive that fits in the bung? I couldn't find any square drive stuff at Sears' website. Also, should I be putting any kind of teflon tape or thread dope on the plug & fill bungs? I may not build the sight tube right away, but I bet I could overfill the trans by doing it on an incline (with the front wheels safely chocked!) Can anyone give me a little advice here? Thanks in advance.
Old Aug 22, 2007 | 05:00 PM
  #41
dsm1's Avatar
I used a small drill pump and some clear tubing. Poured the proper amount in a large container and pumped it from there into the fill hole, then finished off thru one of the top PTO cover bolt holes.
I think I paid $7 for it at Lowes.
http://www.flotecpump.com/asp/Product.asp?PId=317
Old Aug 22, 2007 | 10:29 PM
  #42
Zarrinvz24's Avatar
Just curious to see what you all do, a couple of years ago I had a 93 gasser with the NV4500 and it really liked to start in 2nd. The truck I have now has the Getrag and it hates to start in second. It lugs and shakes and bucks. I start in first now but I don't think that will last too long it doesent seem to like that too much either. Could all this be caused by a clutch issue? The guy I bought it from said it has a "towing clutch" in it, and has no springs. This sound familiar to anyone?
Old Aug 23, 2007 | 01:39 PM
  #43
Check the motor and trans mounts.
Old Aug 23, 2007 | 06:54 PM
  #44
Exekiel69's Avatar
I haven't found this info here, what are this trannys rated for in torque #?
Thank You.
Old Aug 23, 2007 | 07:20 PM
  #45
Zarrinvz24's Avatar
So you should be able to start smoothly in second assuming there is no load correct?
