getrade rebild HELP
Old Nov 9, 2008 | 04:39 PM
cfarmer's Avatar
Unhappy getrade rebild HELP
well when the trany got stuck in reverse and would not come out i had to remove it. what i found was the spring loaded tooth under snik ring jump part way out and block ring from moveing off reverse. Now iended up replaceing-input shaft,mainshaft,all the bearings. New shims for bearing perload of 0.007th. by the manal. I also replaced springs,*****,teeth,under sink rings. now back together with 4-5 noisey removed tranfercase to alemant that the noise is in the trany ANY IDEAES
Old Nov 9, 2008 | 04:45 PM
PapeCAT's Avatar
preload looks good and correct. Definitely a head scratcher. In what condition were your shift forks? Worn out or bent?
Old Nov 9, 2008 | 05:00 PM
cfarmer's Avatar
shift forks look good to new one i got 5-reverse
Old Nov 10, 2008 | 03:59 PM
cfarmer's Avatar
i am going to remove the shimpack to do a recheak to make sure i did not fumble the meserments
Old Nov 11, 2008 | 02:25 AM
rockfoot's Avatar
Make sure the bearings are preloaded and not clearance fit.
staken
Jul 26, 2008 07:29 PM
cfarmer
Feb 17, 2008 12:31 PM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
