Gasket !!! Left side.
Old Mar 27, 2015 | 02:54 PM
whosdunit's Avatar
My 91.5 D250 leaks oli down the side of the mtr. . I would like to replace the gasket in behind all that "stuff", it's not a bad ( or big) leak ,,,,it just looks bad ,,,just don't know what to call the gasket down at the parts house,, a part # would be great ,,THANKS
whosdunit.
Old Mar 27, 2015 | 05:27 PM
patdaly's Avatar
Tappet cover gasket. Also called push rod cover gasket.
FEL-PRO Part # PS50397R
VICTOR REINZ Part # PS38801
Pain to change.......... gasket is cheap though.
Old Mar 27, 2015 | 06:33 PM
whosdunit's Avatar
Thanks ,Pat,,sounds like you been there done that! How hard is it ,,,2-3 hrs. ,,,?
whosdunit.
Old Mar 27, 2015 | 08:08 PM
Philip's Avatar
You need to remove the injection pump and almost every thing of that side of the engine.
Old Mar 27, 2015 | 09:14 PM
sooty's Avatar
are the cover bolts loose?
Old Mar 30, 2015 | 06:42 PM
whosdunit's Avatar
Hey gang,,???? Didn't think about that,,,man wouldn't that be just alright,,,I'll give them a try ,,. It won't happen until the weather is a whoooole lot warmer if I have to do it( put in new gasket). Thanks '
whosdunit.
Old Apr 1, 2015 | 01:44 AM
Rick 12v CTD's Avatar
I hate the stock tappet cover...
The first motor build I did, I replaced that gasket and everything properly and the tappet cover leaked worse than ever. Said "screw it" and ordered a billet tappet cover, which after my latest build leaked too, figures
Stupid things... or maybe stupid me, who knows.
Old Apr 1, 2015 | 09:12 AM
j_martin's Avatar
I learned how to put on a tin cover or pan 50 years ago when I was hangin' around Danny Barthelemew's garage.
When the screws are over-tightened, they'll deform the metal inward. That can cause leaks immediately, and deform the metal so a new gasket won't seal.
1. "Straighten" the cover, defined as using a small ball peen hammer to form each screw area till it's flat to slightly raised from flat.
2. Clean and scrape the pan and the mating surfaces.
3. Apply the appropriate adhesive. Used to be Permatex #2, now usually Permatex blue.
4. Install the pan, tighten to just snug, usually seen as squeezing adhesive out.
5. After adhesive sets, torque the screws, but not enough to visibly deflect the metal. This varies widely on the application.
6. If in a difficult to reach spot, or just to to do a special good job, back out each screw one at a time, apply loctite blue, and reinstall to torque.
The two key events are straightening the cover, and not over torqueing the screws.
Old Apr 2, 2015 | 03:18 AM
yeah back then I didn't think to do it when I rebuilt the motor and by the time I discovered I had to fix it after the motor was in the truck and running I was too irritated to bother with the stocker at that point. I just ordered the billet
imo the stock tappet cover is a pretty cheap piece considering how everything else on the motor is so durable
hog_hunter_57
Jul 26, 2007 04:51 PM
cbrahs
19
Jul 26, 2007 01:04 PM
54larry
Feb 21, 2007 04:32 PM
TRX24V
13
Feb 11, 2007 07:37 PM
Bobcat698
Jun 4, 2006 08:21 AM
