Fuel Pump
Old Jul 4, 2012 | 01:30 PM
1972RedNeck's Avatar
Fuel Pump
I noticed my fuel pump had a small sweat the other day. Should I get a stock replacement or is there a better one out there?
Old Jul 4, 2012 | 03:16 PM
93flatbed's Avatar
Lift pump or high pressure pump?
Old Jul 4, 2012 | 05:57 PM
I have read that fuel pressure can drop to 0 psi at wot. I don't want this to happen.
Old Jul 4, 2012 | 07:29 PM
Exekiel69's Avatar
Do a search for low pressure lift pump and You'll find tons of info with everyones opinion on this matter since many have gone through this already and there a good points of view You may not see with this thread alone.
Old Jul 4, 2012 | 10:46 PM
I just did a search. The only problem is, it wouldn't search. I'm going to bed before I get the 12 Ga. and fill the computer with double ought buckshot.
Old Jul 5, 2012 | 03:13 PM
Exekiel69's Avatar
In that case, the part # for the low pressure lift pump I got is HFP702 You can order it form oregon fuel injection along with the spacer and two gaskets. It will deliver about 10-12psi low idle. It is good to know of any leaks from the injection pump in case some develop afterward.
Old Jul 5, 2012 | 03:29 PM
DodgeFreak's Avatar
or if you wanted to run a fuel pressure regulator you can get one from a 2nd gen hplp and then run a return style reg and regulate it down to 13-15psi.
ScreaminEagle
Oct 31, 2007 03:31 PM
Stevie G
13
Aug 4, 2006 10:27 PM
Gene
Sep 10, 2005 09:32 PM
Commatoze
19
Aug 8, 2004 09:57 PM
TPilaske
16
Nov 22, 2002 08:15 PM
