Fuel mileage
Old May 16, 2012 | 10:47 PM
kellypckp's Avatar
Kelly I use to beable to pull down 18 on highway with my old crewcab but you have to remember us crewcab guy's have more weight and length on our truck's also so your right in there with what you have right now might beable to do a little better tweak it somemore and see what happen's
I think I am happy with 16. As big as it is, not nearly as big as yours but it is big .. It is not as quick when it was a standard cab and 265 tires thou. Will need to do some tweaking later.
Old May 16, 2012 | 10:51 PM
simplysmn's Avatar
well as you saw mine it did pretty darn good on fuel and the truck I'm building now will be same height and size but this 1 will have power door's and mirror's N new baja ta 37's but also have 410's that may be your problem is gear's ?
Old May 16, 2012 | 11:44 PM
CIRCE's Avatar
Seeing 19.2 & 19.7mpg lately for combined city/hwy, most of
that in town. Have yet to make a road trip. (All stock)
Can't complain!
Old May 17, 2012 | 08:47 PM
J-man's Avatar
Can't complain!
Sounds just about the same as mine. I was getting around 18-19, but on the first full tank since the intake, turbo, and turning the fuel screw in more, I got a 19.7 on a 750-ish mile tank. That was rolling some coal and not really highway miles either! Leaving tomorrow for an 8 hour road trip, so we'll see what that nets.
Old May 20, 2012 | 07:49 AM
1STGENFARMBOY's Avatar
Just got back from a trip, ran out two and a half tanks with O/D off and cruse on set at 55 mph, got 13.9 out of one tank and 14.8 out of another, with this in the bed.
tranny temp was to high to leave it in O/D even with an aftermarket cooler with fan. guess it's really time for a converter.
Old May 20, 2012 | 04:14 PM
crazy clem's Avatar
holy wind resistance batman, I guessthats why the best way to haul is with a standard. after ayear with my tighter converter Ive picked up 2 mpg and on the hwy at 55/60 lost 300 rpm
Old May 20, 2012 | 04:22 PM
mtdoragary's Avatar
At 55, I get almost 20 mpg pulling a 14' flatbed trailer loaded down. get the same without the trailer. Ext cab, 3.54, 518. One day I'll get a Goehrend convertor. Can't do over 55 without wheel hop.
Old May 20, 2012 | 08:01 PM
1993 250bluebal's Avatar
My W250 is completely stock, the smoke screw cover hasn't even been pryed off and I get 19.2 every tank full. Now I only drive 65 mph max cause the transfer case wants to come and sit with me in the cab, LOL. I can't get mine to smoke at all in the daylite but when some dope is tailgateing me at nite, I'll slowly bring it up to 73 mph so they'll follow close and then I'll pin the pedal to the floor and in his headlites they'll get blasted with the prettest Diesel haze, they fall back pretty fast.
Old May 20, 2012 | 08:32 PM
j_martin's Avatar
http://dodgeram.info/tsb/1992/22-02-92.htm
hope it helps
Old May 20, 2012 | 10:30 PM
jimbo486's Avatar
I drove up to Apple Valley, CA today for some parts and filled up before I left. 193 miles round trip and still have just under 3/4 of a tank (~8gals used). Half of the trip there was ascending a 6% grade. Calculated out to 24.1mpg. Ok, so maybe descending the 6% grade aided some . Around town, back and forth to work, 14mpg . I'm hoping a custom tuned injection pump may help. It'll be hard to keep my foot out of it for a while though .
D350 Cab & Chassis 159" WB
NV5600 (6th: .73)
235/85/16s
3.54 rear
Old May 21, 2012 | 12:48 PM
diesel402004's Avatar
Nice 1STGENFARMBOY. I can see why that would be straining the 518. My "super cooler" fan comes on even without a load and that is quite the load you have!
Old May 21, 2012 | 02:30 PM
Hey Dar,
Are you going to paint that giant "sunvisor" you have on your truck from the white whale color to the silver / green combo. That's one big heavy sunvisor.... !
Old May 21, 2012 | 05:29 PM
J-man's Avatar
New best of 20.8 mpg highway!
Old May 21, 2012 | 09:38 PM
Originally Posted by NJTman
Hey Dar,
Me and momma sit in the shade no matter what time of day it is...., it does ok except for the trans temp and a little top heavy sway.
i have got to add a big wig sway bar.
Old May 21, 2012 | 10:01 PM
DJ Turbo.'s Avatar
Seems that it varies majorly but a light foot helps lol
