fuel heater
fuel heater
Hi guys I did a quick search but could not find any real info on the fuel heater that is on the top of the fuel filter. When is it powered up? What I want to know is if it is on all the time or is it controlled by the computer to only run at certain temperatures. I won't have a computer in the crew cab but would like to avoid gelled fuel if possible.
Thanks Grant
Thanks Grant
On the first generation engine, I believe there is an internal temperature switch that opens the circuit above a certain temperature. I do know the computer doesn' t control that circuit.
It's gotta be an internal switch because the wire that feeds it is hot when the ignition is on. The manual says it kicks in between 43 and 53 degrees F. Man, it's nice having wiring diagrams.
rjm022
Dec 11, 2019 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
