Fuel gelled again!!
Location: North Haven,CT "Living in occupied teritory" & Barton,VT
Fuel gelled again!!
I came back from a 23mile drive last night around 11:30 and not a problem. Went out this morning around 9am and it started, ran for 10sec and shut down. My fuel light came on when I was coming down my road so I know I was low. I have had this truck in northern VT with -35* temps and I never had a problem. Now this year I'm in southern CT and she gelled twice on me with warmer temps, nothing below 0*. This truck NEVER gelled on me. Sorry for the rant. So, is it the new fuel, something I'm doing, or do I need to replace something? Also is anyone else having this problem?
I filled the fuel filter with 911 to get it started and poured the rest in the tank. Filled the tank and added 8oz of Power Service. Its the thought of the added cost of the additive, on top of the soaring fuel prices, and the fact it never did this before that's galling me. I just thought it would be something simple like a worn part that could be modified, changed or replaced.
Crobar: You are probably right, this truck spent its first 15yrs up there. If I could find the job I have down here up there I would be back in an instant!
That's what I was hoping to hear. I just got in my fuel pressure gauge and when I find a place to mount it and get and idea of the stock pressures I'm putting in the 2nd gen lift pump, Mallory Regulator, and the 7x010 injectors. I am thinking about doing that larger fuel line mod also.
I feel your PAIN! I too gellled up this morning around 4:30 on my way out of the neighborhood where I live and made it about 3/8 of a mile from house. It was cold here yesterday and last night below zero around -10. I had filled on Sunday and poured in a double dose of Howe's just to make sure as the forecast called for more cold this week. The place I filled from just happens to the same place that I filled from the last time I gelled back in January. I think their winter blend must straight #2. I have used another places' winter blend for a couple of years and NEVER had a problem. Guess that is what I get for being lazy gong the convenient place and not the one the won't screw me. Anyway another round of change the filter and bleed injectors. Hope you get it going and have no troubles.
I second this. . . mine was doing this stuff a couple years ago . .It had a weak lift pump & plugged filter in the tank.
May not be getting winter feul down there. Also when you drive down the road wind will increase the cold on the feul lines. I live in Alaska and when I went to the big line kit, when I did I went down to Lowes and picked up that pipe foam for insulating pipes and wrapped that around the feul line come from the tank all the way up to the injection pump to keep direct wind from hitting the feul lines. Also waiting till the tank gets low on feul can cause condensation in the tank and when that happens water is in the fuel and will gel. The heater is part of the fuel filter and if water is in the fuel and its cold enough it will gel before it hits the feul filter and it doesn't take much gelled fuel to plug a feul filter.
