front brake problems
On my 89 W250 I have had a lot of trouble with the front brakes causing the front end to shake, badly at times when stopping. Turned the rotors,not much help. New shocks, no improvement. The truck has low miles and the front end is still tight. Are 4 wheel drives prone to this problem? Any ideas to fix? I have put the larger wheel cylinders and 3" shoes on the rear to help stopping as I pull a trailer a lot.
From: Michigan (see aforementioned rusted-out rockers)
tires are also a possibility. if it also does it to a much lesser extent when you get off the throttle, then brakes have nothing to do with it. it's tires or alignment.
dieselluvr
Dec 29, 2013 11:02 PM
Mr. Jimmy
Mar 28, 2005 08:29 PM
