Front 1" leveling springs
Good morning everyone, first and foremost, Happy Holidays and God Bless yall your loved ones!!
I am currently looking for new front leaf springs to replace the original, im assuming, 26 year old springs my truck currently has. They have a negative arch to them. I can barely fit my hand between them and the bump stop. I am looking to get the skyjacker 1inch leveling d100cs springs. My question is, is anyone running them and how tall are they in the front. I like the stance my truck has right now and wouldnt like it to change due to taller springs (thats why im going with one inch instead of the 2 inch d200cs). Current measurements from the ground up along the middle of the wheel to the fender lip is 37 1/8" up front and 38 5/8" in the rear. Please excuse the long post, but i am looking for yalls recomendations on this. My main concern is not wanting the rear sag.
I have 1 ton rear spring packs I break down, and add a used longer leaf to compensate sag, if you decide to do this, when you have them apart you need to replace the center bolts, theres usually enough u-bolt thread to add up to a couple if necessary. im a fan of the 4" kits, very reasonably priced, and look awesome, I you really want new, say the word, ill get a resource near you, where ever that might that be??
The old worn out stock leaf springs on my 1992 W250 rode extremely harsh, and I replaced them with the exact ones you're looking at--the 1" Skyjackers. It still had a very slight nose down attitude, but the ride was sooooo much better!
It was one of the best things I ever did to that truck.
Do you happen to know how much lift you got after replacing the old springs? Do u know how far apart the new spring sat from the bump stop? Thanks for your replay bud.
If you don't get enough of a lift from new springs, try these. Cheap and easy 1". They are not like a block either, they are like an overload leaf cut down so it doesn't affect the ride.
DIY 4x :: Suspension :: EZ Inch Kit
Thank you BILTIT for that idea, i had never seen that before. I will soon be ordering those springs, i just wanted to have other peoples opinions over this matter. This is my first 1st gen and have never done a leaf spring swap. Reading other posts over this topic provides plenty of information to tackle such task. Thanks everyone for your replies.
I run the skyjacker 2" springs in the front with a 1" longer shackle, so theoretically, 2.5" of lift. It sits dead level. I got about 2" of lift after 2 years of driving on them. They ride great with a good heavy shock, skyjacker m95 monotubes is what I run and recommend.
I have actually used these on a K5 Blazer in the past. I have mixed feelings on them. I didn't notice any difference in ride. They were a little longer than the actual spring perch on the d60 I put under it. (Chevy version of our front axle)
I went with them as they bolt to the leaf pack via the center pin which they supply a longer one.
If you go this route I would suggest trying to find a higher strength/quality center pin to use instead of the ones that come with the kit. As I had the unfortunate experience of shearing off the center pin the first time I took the blazer out wheeling which resulted in catastrophic damage to the transfer case as the axle slid back and pushed the driveline back into it.
So so with my experience I throw my hat in the ring with the "could create leverage" crowd.
archer39
04-14-2012 01:32 PM
PEAKSTRYDE
10-11-2007 04:20 PM
Holiday
06-21-2005 10:34 AM
Joe Diesel
10-06-2004 07:45 PM
