Free Dramatic Boost Increase
Old Jan 1, 2007 | 06:42 PM
BearKiller's Avatar
Wink Free Dramatic Boost Increase
When I swapped engines, I un-hooked the boost gauge line and tucked it out of the way; then, once the Cummins was in, I screwed it back in.
I never was impressed with the boost numbers with the International, compared to what others were getting with less wicked set-ups.
With the Cummins, I had been seeing a maximum of around 15 PSI.
I accidentally got against the plastic gauge line, where it goes into the fitting in the intake horn, and broke it off.
I unscrewed the fitting and managed to rescue the little ferrule, cut the line off clean, and reassembled.
Now, without spending a cent, I can bury the needle on the boost gauge (it goes to twenty).
I wonder how many others out there, including oil-pressure and others, could benefit from the same treatment.
Old Jan 1, 2007 | 06:44 PM
Boatnik's Avatar
That is why I like the copper lines better.
Old Jan 2, 2007 | 07:58 AM
Ace's Avatar
Ace
That's why I install those tiny nylon lines inside a larger, protective sheath with plenty of support at the stress point:
http://66.17.171.114/PhotoAlbum/Cars/Pics/CTD_40.jpg
But, like Boatnick said, hard lines are best if you got the time and money.
sCreamin400
25
May 10, 2010 10:14 PM
Mark Craig
Aug 26, 2005 07:57 AM
Mark Craig
Aug 25, 2005 04:22 PM
Patrick Campbell
Feb 24, 2005 02:38 PM
