Flip shackles Pics
as it sits right know, I am at like 7 degrees from pinion to driveshaft, I usally like keeping it around 4 to 5. So I need to do a 2 or 3 degree shim, but I have to wait until I do the front end to be sure. I might end up machining a 1" riser block on a 3 degree angle to get a little more lift in the rear if I have too. Ya that pic is at Silver Lake
Ya, I used a satin black and then I waxed the snot out of it just to give a semi gloss look. It Is actually a hood from a 77 powerwagon, I was going for the old muscle car look. Flat black Hood.
make a second set, send them to me, then I will let you know
Would love to do this on my truck (on a long list of things to do!). Spending to much time on my rockwell'd Toyota though.
Course, there is no weight on it yet but you would get a better ride with a shackle angle of around 45 degrees. A shackle that short moves pretty quick though, so the bed might get it close.
Great combo with this up front
https://www.dieseltruckresource.com/...light=rcc+lift
Andy
Andy
Out of curiosity.... where did you get the flares you have on the front of your yellow beast? I am looking for something similar for my 1985 Crew Cab, are they Bushwhacker and if so you happen to have a part#?
Thanks
Thanks
81-93 Dodge Ramcharger, Trailduster, Pickup 2wd & 4wd
Front Part # 50007-11, Rear Part # 50006-11
http://www.bushwacker.com/fender.asp...&search=Search
these are the ones I have. After I cut out the fender, I made custom inner fenders that I used a roller machine to get the right bend, If you try to reuse the stocl inner fender, you have to cut it up pretty good. I didn't like the way it looked, so I made my own. Once you cut the fender, you have to make a new lip on the inside of the fender to have a backer. They are a bunch of work. But To fit bigger tires, they are a must
Andy
Andy
Looking back at it, I probably should have put them on a little more of an angle. But, I can always move them foward if I have to. After I get the front end done, I will finish the back. I am putting a 2.5 spring in the front and possible a drop shackle. I kind of did it *** backwards. I usally like to start in the front of the truck. But it was cheaper to start in the rear.
i like that hood to and the rear axle link great idea my old ford with its 460 and 5spd. and my lead foot could rap that axle up and spit out 4 pieces of my driveline, got expensive and after ladder bars it never rode right.i also like the t-case clocking is that divorced? cool bed
Thanks for the picks i wanna do King Coils and link it up whatcha think on a 1st Gen. wita CUMMINS STD. cab longbed
CTD NUT
Mar 21, 2005 01:54 AM
PZM123
Nov 23, 2004 03:16 PM
1320
Aug 5, 2003 12:04 AM
