Flange Lugnut torque?
These are the only lug nuts I use the air wrench to tighten. All the other vehicles I work on are tightened with a 4-way lug wrench so they can be removed on the side of the road with the factory tools...
I broke about 4" off the end of the factory torque bar... But then I have the wheels off mine more than most
. Too many loosen/tighten cycles,adn it work hardened just past the thru hole point. If it's tight enough to break a 3/4" thick steel bar it's **** tight!!!
halerazor
Jan 4, 2005 11:32 AM
