fire rings
They are actually just o-rings unless you have your block machined too. they should fit but as mentioned you would need to machine the head. Not sure about the gasket.
Depends on your bore size and diameter. IIRC I used .105 wire with a stock thickness headgasket. http://www.haisleymachine.com/Head%2...0&%20Studs.htm. You might try calling Haisley first before you buy.
ahire
13
10-17-2008 12:50 PM
12VRoush
10-15-2007 08:00 PM
1320
03-08-2005 08:56 PM
