Finally towed something! Need intercooler
Old Apr 9, 2010 | 08:45 PM
  #31
Benjamin b2's Avatar
Originally Posted by dzl_damon
You'll have to cut off the front of your frame that sticks out past the radiator... you'll have to do something different with your bumper mounts. Someone has a picture on here of it mocked up with the front of the frame hacked off. Tall is the issue as mentioned.
And a note that Non I/C trucks have bigger injectors than the IC trucks stock. They can push the fuel MUCH more than the IC's when the pump is breathed on. My 89 could run circles around my dually untill I upgraded the sticks...
Alright, you do have to cut the frame horns off, i welded a channel iron to build bumper mounts and build my frame up and built a "trough" for the 3rd gen intercooler to sit in, i capped the ends and bolted the bumper horns to the outside. I then just widened the bolt possisions of the bumper in porportion to how much i had widen the mounts and drilled the bumper. The the holes for the inlet and otlet are in the perfect spot, my intercooler is level with the bottom of the frame, i cut 4" holes in the core support for the boots, you cant use a hood saftey latch, the top angle brace where the hood latches has to be trimmed for the top of the intercooler, i trimmed the intercooler brackets completly clean so there was nothing but intercooler and no factory brackets. with a cut off wheel and buffed it smooth and painted it. tougher than the factory. i cut a rubber mat for the bottom of the inter cooler and it sits loose in the trough and i built simple brackets for the top. the grille and valance dont need to be trimmed, i didnt have ac or a tranny cooler to worry about. i pretty sure that my intercooler is not going to come out of its hole with out taking the whole front end apart.
and yes its magical
Old Apr 9, 2010 | 11:30 PM
  #32
schamran's Avatar
I would rather not do away with my hood safety latch though. Maybe I will just go the Power stroke route. It should be plenty big enough for what I am doing anyway.
Old Apr 11, 2010 | 11:44 AM
  #33
good idea, as much work as it was, im more than happy with the results, its nice not watching the pyrometer now and then.
Old Apr 11, 2010 | 06:14 PM
  #34
schamran's Avatar
My buddy is parting out an '03. he wants $150 for the cooler, so I might go to work and shorten it, or cut apart my bumper mounts. I'll jump off that bridge when I get there. lol
Old Apr 11, 2010 | 06:22 PM
  #35
KD93's Avatar
Nice!
Old Apr 11, 2010 | 09:13 PM
  #36
schamran's Avatar
Scratch that it's $250 for the cooler. What do you guys think. I still have to cut it up and have it welded. What would scooby do?
Old Apr 11, 2010 | 09:17 PM
  #37
pwrtripls1's Avatar
scooby would buy my stock IC and pipes. LOL
Old Apr 11, 2010 | 09:19 PM
  #38
schamran's Avatar
Sorry man. I'm trying to loose the "stock" idea, a little at a time.
Old Apr 11, 2010 | 09:21 PM
  #39
92smokin blacky's Avatar
You could get a PS intercooler for $75 to $125 i bet and it'd be a lot less work and it would do the job well
Old Apr 12, 2010 | 12:50 PM
  #40
schamran's Avatar
I will have to look around for one then. Thanks Austin.
Old Apr 12, 2010 | 12:55 PM
  #41
Yeah i priced one for $125 at a local scrap/semi/truck junkyard so i bet you could find one for about the same. I plan on upgradin mine to that soon too so i have full 3" all the way through.
Old Apr 12, 2010 | 12:58 PM
  #42
schamran's Avatar
I was actually kinda thinking about paying it, if I could get the intake horn, boots, clamps and all the tubing.
Old Apr 12, 2010 | 01:00 PM
  #43
for the 3rd gen intercooler?
Old Apr 12, 2010 | 01:05 PM
  #44
schamran's Avatar
right $250 for it all. Found an intercooler for a 99 ish powerstroke with all pipes for $100, but it's in Louisville Kentucky. Don't get down there very much. lol
Old Apr 12, 2010 | 01:08 PM
  #45
Yeah i guess it'd be a pretty good deal if you got all the pipes, intake horn and clamps. I'd say go for it.
