Factory fuel screw settings????
Old Feb 22, 2010 | 06:46 PM
dstad's Avatar
I'd like to know how many turns my fuel screw is turned in. Does anybody know how many turns it would be from the bottom out to the factory location.
Old Feb 22, 2010 | 08:40 PM
dstad's Avatar
Bump Bump Bump
Old Feb 22, 2010 | 08:51 PM
Benjamin b2's Avatar
my 93 was 1.5 turns from the collar, my non ic 91 was almost a full turn from the collar, if you can see where the collar used to be, you can almost guess where it was stock. hopefully this helps.
Old Feb 22, 2010 | 09:28 PM
dzl_damon's Avatar
my 89 was only about 1/2 turn from the collar. They are all different.
Old Feb 22, 2010 | 09:31 PM
Richie O's Avatar
366 Spring Chicken
They are all different as DZL DAMON says. The pump is set at a flow setting from the factory. They run the pump on a stand and adjust to the flow rate to what they are after.
Old Feb 23, 2010 | 09:32 AM
DNRCustoms's Avatar
On average the ones I have done have been about .700 from the backside of the lock nut to the end of the fuel screw. this is on i.c models, non i.c ones are like .600 I think!!
jmd4993
Jun 22, 2013 07:36 AM
Blowndodge
May 19, 2011 09:43 AM
loudcummmin
Oct 3, 2005 02:44 PM
