f800 cummins p7100 pump
Old May 14, 2011 | 07:58 PM
mullishacrew's Avatar
hey guys i just yanked a cummins 5.9 out of an f800 the motor got scortched, the exhaust manifold is white and the head is white where the exhaust port come out, and the gaskets are all wheeping as well as the motor will not roll over i took a breaker bar on it and kept jerking it back and fourth and nothing, i took the steering pump out and looked in the gear case and no teeth or carnage layin in there, but anyway the customer who owns the moving truck/ junk yard, said if i wanted to we could trade my leighbour to remove the motor and trans and re install for the p7100 pump, and anything i need to make it work. now my question is will the injectors in my 93 work with the p7100? is this trade worth it?
Old May 14, 2011 | 09:33 PM
d22019's Avatar
It sounds like it melted more than one piston. I would try to get the whole engine since it sounds like the engine is beyond repair. You wouldn't happen to have pics of the manifold and stuff that got really hot would you?
Old May 15, 2011 | 12:48 AM
well i dont know if i can pack the motor around to long, i am in the middle of lookin for work and prepared to move just wanted what i could use. no pictures yet, but i will grab some next weekend!
Old May 15, 2011 | 08:01 PM
crewcabxlt's Avatar
injector bodies are different but get all the rest and the p-pump innjectors and put your nozzles on the bodies if you want. take all the conversion parts. i can list if you need me too.
Old May 15, 2011 | 11:29 PM
the pump will bolt up to the existing gear case?
Old May 16, 2011 | 10:13 AM
crewcabxlt's Avatar
no, you need gear housing, cover, lines, brackets, oil feed lines for pump, lift pump and lines. afc tube etc.
td3620
May 6, 2011 01:29 PM
bizkit
17
Dec 21, 2006 01:18 PM
hvanflee
14
Oct 27, 2003 12:21 AM
jimrob
Feb 27, 2003 12:33 PM
