External voltage regulator overcharging
Old Jan 6, 2016 | 10:21 PM
  #31
Ol-dodge1992's Avatar
Alrighty ... I have three vehicles... My dodge, wife's ford, and Yukon XL I'm trying to sale ... I'm gonna test all three tomorrow after they have idled and come up to temp. ... I can probably borrow another multimeter to test with as well
Three different vehicles... Two different multimeters... ???
Jmartin I can't thank you enough for your patience and wisdom
Old Jan 7, 2016 | 06:23 PM
  #32
Well fellas ... I tested three different vehicles with two different multimeters today ... Here are the results (the first reading is my multimeter, the second is borrowed) ... Readings are at battery terminals after idling for 5-6 minutes
92 dodge CTD ... 15.1...14.9
07 ford exp. ... 14.2...14.0
04 gmc yukon... 14.3 ... 14.1
Now I can't say if my meter is high or the borrowed meter was low but ... They were completely consistent in the 0.2 volts difference across the board... Later on I even got brave enough to check my house voltage from an outlet with my meter... 120.7.
I'm pretty sure I'm charging almost a full volt high ... What is the extended damage probability?
Only gonna be on the VR for a couple weeks as I'm getting ECM from stateside... And I only drive the truck 20-30 miles a week
Old Jan 7, 2016 | 09:45 PM
  #33
Hillbilly66's Avatar
From everything I've read on these external VR's, it's not supposed to matter which wire goes to which terminal. But have you tried switching them around to see if it changes anything?
Old Jan 7, 2016 | 10:37 PM
  #34
Yep no change ... Would the ASD relay have anything to do with high voltage reading
Old Jan 8, 2016 | 08:02 AM
  #35
patdaly's Avatar
ASD should have nothing to do with it.
It could cause a no charge condition if you were running thru the PCM though.
Old Jan 8, 2016 | 10:23 AM
  #36
The only other thing I can think of doing, would be take the alternator off, and carry it into a an alternator shop, or Napa if they can bench test, and have them test just the alternator, to see if it's an internal problem with the alternator.
Old Jan 8, 2016 | 12:56 PM
  #37
My alternator is less than 2 months new ... It would charge fine (although I never checked it with multimeter just the dash needle) before I installed the VR ... The catch was that it would not charge until after the truck was really warm and "something" made electrical connection (I assume and am almost positive it's the ECM) after the engine got warm enough.
The old alternator would charge after whatever got warm enough to make connection ... The battery needle was little over the 12volt mark
The new alternator would charge after whatever got warm enough to make connection... The battery needle was much closer to the 14volt mark
I decided to install the VR only temporary so I could get ECM remanufactured (having BIG trouble getting that done) ... That's when I started checking stuff with multimeter... Grounds, shorts, volts etc...
Old Jan 8, 2016 | 02:03 PM
  #38
Supposedly oreilly's in the states can send your PCM in to get rebuilt, other than that finding a used one is about the only option I know of.
Old Jan 8, 2016 | 03:45 PM
  #39
Just got off phone with Oriellys not five minutes ago and they have no stock.
I'm starting to think I'm gonna have to "de-computerize" the CTD... I've got a few options for used parts but you just never know
Old Mar 15, 2016 | 10:58 AM
  #40
The Sarge's Avatar
Ol dodge let me know what you find out. I am having the same problem to a T.
Old Oct 2, 2020 | 12:38 PM
  #41
Shiny's Avatar
Hows it going?
So what was the outcome?
I have the same thing going on with my truck. Keeps blowing the VR every 2000 miles or so.
I think I will just delete the ECM but cab not find a simple straight forward list of how to do it.
I have a '92 CTD dually 5 speed truck with 190k miles on it. Speedo or odometer dont work, along with a bunch of other things.
Can anyone help me out?
Thanks!
-Shiny
TurboAZ
Aug 27, 2013 09:26 PM
jcb
May 7, 2006 08:03 AM
flycl65
Jan 26, 2006 12:00 AM
westcoaster
Jun 23, 2005 10:56 PM
banks twinram
May 1, 2005 10:35 PM
