engine rebuild kit
Old Aug 2, 2009 | 07:02 AM
95ram's Avatar
engine rebuild kit
How's go the best prices on the rebuild kits. I'd like to stick with cummins parts. Does anyone know of an online place that has good deals on gaskets?
I'm going to be resealing the engine before it goes in the crew. I'm planning on doing the front and rear main, oil pain, front case, head, valves, and vac. pump. Anything else anyone can think of???
Old Aug 2, 2009 | 07:14 AM
77machomopar's Avatar
i would use only cummins parts. I saw someone recently say a top motor gasket set was around $200 from cummins.
Old Aug 2, 2009 | 11:56 AM
jimbo486's Avatar
$213 through cummins. $231 after taxes here in california.
here are the parts lists they faxed me
make sure you have 12 valve stem seals. they're the blue-tipped cups near the lower right of the pic. my kit was short 2 and i had to drive back to get them.
Old Aug 3, 2009 | 12:32 AM
95ram's Avatar
jimbo, that's just the upper gasket set right?
I'd like to find a whole gasket set. The enging only has a little over 200K, but Leaks oil. I figured since I'm pulling it anyways I'd just reseal it.
Isn't there an in frame overhaul kit???
Old Aug 3, 2009 | 02:09 PM
jimbo486's Avatar
yes that is just the upper engine gasket kit. i was just responding to machomopars post about someone recently buying the upper kit. that was me!
i know they have a rebuild kit. i've ordered some when i was in school for the motors i rebuilt. cummins has anything you need. you should even be able to get pistons, rings, rods and bearings from them as well. any part you'd need to rebuild your motor should be included in a rebuild kit. give your local cummins or cummins dealer a call and ask them to fax you a parts list. they were more than happy to fax me one for the kit i bought.
topshelf
Jun 26, 2012 09:52 AM
Ilikebikes
Oct 11, 2006 07:56 PM
jughead
Aug 4, 2005 12:25 AM
