Engine oil temp sender.
Old Apr 4, 2008 | 06:26 PM
Montana2x2's Avatar
Where is the best place to put an engine oil temp sender. Seem that if it could be put in the line where the oil drains from the turbo it would give you the highest temps. Is it possible to do that? Thanks
Old Apr 5, 2008 | 05:35 AM
Our engines have an oil cooler, so oil temp runs pretty close to coolant temp. It's not really necessary to monitor it. If you are just the curious sort, go right ahead. The sender should go in the pan, you don't want any restriction in the turbo drain.
Old Apr 5, 2008 | 05:36 PM
Montana2x2's Avatar
I have a guage kicking around and figured I better use it before I lose it. Thanks
Old Apr 5, 2008 | 05:42 PM
It would be more interesting (and useful) in the Getrag.
Old Apr 5, 2008 | 06:15 PM
Montana2x2's Avatar
Never thought of that, that will be more useful. Thanks fot the jumpstart.
RobG
Jan 14, 2014 11:05 AM
e2360
May 15, 2004 08:44 PM
Reelay
May 6, 2004 07:29 AM
apache
Mar 3, 2004 07:27 AM
country
Aug 18, 2003 08:14 PM
