Engine Flush?...ya or nay
"Not needed. If the water pump goes it's extremely easy to change. Drain the radiator, pop the belt off, remove 2 bolts - and the pump is in your hand."
Unless the idiot people that owned the truck before you broke off one of the bolts and drilled another hole through it and into the block right beside the old one, rather than extracting the old bolt and doing it right. Happened to me,,,
If your coolant looks bad, a good flush is good. The extended life coolant is best. Always use a coolant conditioner for initial fills, then once per year. The conditioner will keep the PH correct and prevent corrosion and break down of the coolant. It also prevents cavitation of the coolant around the cyl walls which will errode holes thru the cyl. It keeps the complete cooling system in good working order. Semi's that use extended life coolant and conditioner can run 1,000,000 miles or 10 years and have a perfectly clean rad and water jackets in the cyls and head.
It also prevents cavitation of the coolant around the cyl walls which will erode holes thru the cyl. It keeps the complete cooling system in good working order. Semi's that use extended life coolant and conditioner can run 1,000,000 miles or 10 years and have a perfectly clean rad and water jackets in the cyls and head.
CACalomino
16
Mar 22, 2010 06:35 PM
Sam Turner2
Nov 18, 2008 10:17 AM
