Engine Fan? is it worth changing to electric fans or no fan?
I will add that the biggest road-block to a 1st Gen. Dodge/Cummins keeping it's cool in a genuine towing situation is that puny little radiator that would be more at home in a little 4-cylinder car; I mean that thing is tiny.
Please pardon the interuptions in my postings.
Ever since the changeover, I can be typing along and right in the middle of a sentence, it will instantaneously post whatever I am typing.
I mean it jerks my post away from me and instantly it is posted.
When I actually click "submit" it piddles around for five minutes before I get any action.
I can't figure what Chrysler was thinking in putting such a small cooling system on what was to be a genuine gooseneck hauling rig.
Please pardon the interuptions in my postings.Ever since the changeover, I can be typing along and right in the middle of a sentence, it will instantaneously post whatever I am typing.
Stock fan nut is 33MM I believe and LEFT-HAND.
Everyone is always trying to put a CFM value on the stock clutch-driven fan.
I see no accurate reliable way to even get a close estimate of the true down-the-road CFM that a hardly-ever-actually-engaged clutch-driven fan is gonna pull.
The big advantage of decent electric fans is that they are fully engaged at full speed at all times that they have electrical current.
I would not hesitate to tow anything with good electric fans that can be towed with a clutch-driven fan.
I am gonna go the electric route whenever I can get time and money ahead to do so.
Currently, on my personal truck, I am running a direct-drive fan-hub, Flex-a-lite #852 and a six-blade steel Flex-a-lite heavy-duty truck fan, 19" I think.
I cannot feel or tell any difference in power or fuel mileage without any fan at all, with a stock clutch-fan, with a pinned stock fan, or with this solid hub direct-drive fan.
My truck started life as a Ford diesel with the huge cavernous Ford diesel radiator.I have never had any engine cooling issues with any of the various fan set-ups I have ran.
By the time the hot coolant finds it's way through that huge radiator, it has almost turned to ice.
My quest in trying the direct-drive hub was to achieve better non-moving and low-speed A/C performance, and to do so without the possible problems of a pinned fan-clutch coming un-pinned and possibly flying through the radiator.
The direct-drive fan/hub has really helped the A/C situation; therefore, I figure it should also benefit any engine/radiator combo that is having marginal cooling issues.
Yes; I did get the hub and fan from Summit.
I have the fan part-number posted around here somewhere in the thread from when I first got it.
I don't tow that often so I think I would be fine and especially for winter. I'll just keep my fan with me in the back or toolbox and put it back in if i ever need to. I've never heard my fan lock up in my truck before and It was leaking a little when I pulled it off to do my KDP so I'm not even sure if it would or is good, but its never gotten really warm. I'll probably find a good set of electric fans next summer and rig them up along with a temp switch. If I have an overheating problem then, I can put my stock fan back in.
Angry Johnny
Jun 15, 2014 04:29 PM
harley77sg
Sep 20, 2008 03:10 PM
tonystruck
Oct 26, 2007 11:02 AM
