engine checkup
Old Mar 18, 2009 | 10:53 PM
hardheaded's Avatar
engine checkup
what can i do to check my engine to make sure everything about it is working properly? i just spent 2800 dollars having my stock tranny built, new converter, steel planets, transgo shift kit, etc... and im still not making much power aqnd im getting terrible fuel mileage. about 12 mpg
Old Mar 18, 2009 | 10:57 PM
92roughstock's Avatar
How many miles? What has been done to the fuel system- pump/ injector service? Do you have any gauges on it?
Check your lift pump pressure. Adjust your valves. Check your timing. INjectors need to be removed to check pop pressure and atomization.
This should be a good place to start.
Old Mar 18, 2009 | 11:08 PM
hardheaded's Avatar
how do i chekc timing and pop pressure on injectors? do the injectors need to go to somebody for checking
270000 miles and no gauges
Old Mar 18, 2009 | 11:10 PM
hardheaded's Avatar
oh i dont know if this helps or not but it seems to do beter in the evenings when the air is cool
Old Mar 19, 2009 | 12:48 AM
Alwaysworking's Avatar
alwaysonDTR
maybe the intercooler is dirty?
Old Mar 19, 2009 | 11:32 AM
dstad's Avatar
i start with gauges, change all the fluids, kill the kdp, adjust the valves, fuel filters, new lift pump or a fuel pressure gauge, belts, flush the cooling system, check the inter cooler for leaks and clean it, check the air filter. what shape is the turbo in, does it have excessive play up down side to side
Old Mar 19, 2009 | 12:49 PM
fanbrain's Avatar
How would one clean the intercooler. Blow some air through it?
No really, I don't know how.
Old Mar 19, 2009 | 02:07 PM
Pressure washer.
Sounds like after 270,000 miles maybe your fuel pressure is down and your lift pump is bad.
Air filter dirty? All connections between airbox and turbo are good?
CHECK THIS- elbow from bottom of turbo to intercooler is tight and not leaking.
Old Mar 19, 2009 | 03:21 PM
fanbrain's Avatar
Pressure washer.
I get it. Like a radiator.
Old Mar 20, 2009 | 07:05 AM
hardheaded's Avatar
new piston lift pump and new bhaf installed within the last month, ill look into the intercooler to see if thats my problem
Brock
Dec 12, 2006 09:14 AM
planetdell
Nov 8, 2005 06:13 PM
apache
Feb 22, 2004 05:27 PM
Joseph H. Smith
Jan 30, 2004 03:59 PM
