Emergency please help!!!
So today I was playin with the ol ve and my father in law over tightened the banjo bolt that go to te boost tube and broke the head off. Where is the best and or easiest place to find one? I need it soon because she my daily driver
If you have the head and remainder of the bolt you may be able to take it to this place http://local.yahoo.com/info-18953711...y-company-waco and they may have something similar to help you out. It looks like they are open 24hrs. May be worth a shot!
If your talking about the banjo bolt on the afc ??
on mine i took the housing off drilled it a little bigger then tapped it to 1/8" pipe thread then put a big truck air line compression fitting in it with about a 6" piece of airline in a loop going to the manifold. Makes afc adjustments much easier because i dont have to unhook anything just take the 4 screws out and lay it to the side
bango bolt
if you cant get ahold of one i have one on a truck im not driving right now i also live in houston i could meet u half way if u need asap. email me soon.
jthibeault.JT@gmail.com
you could call dennis denny t performance& manchine he is waco somewere he may have one.
[QUOTE=bigjohn92;3117339]if you cant get ahold of one i have one on a truck im not driving right now i also live in houston i could meet u half way if u need asap. email me soon.
call dennis
207 Otis Dr Ste 6a
Waco, TX 76712-6736
(254) 741-6922
call dennis
207 Otis Dr Ste 6a
Waco, TX 76712-6736
(254) 741-6922
FYI
Also next time you are in the wrecking yard, check out the section with the older Volvo's, Mercedes and VW's, they all used Bosch Fuel Injection systems and have braided steel lines and banjo fittings of different sizes all over the fuel system.
The cars are also plentiful with Bosch 5 prong relays usually for the taking.
Jim
Jim
