easy mods..need help!!
Old Mar 6, 2007 | 09:55 PM
93beater's Avatar
ok i really want to do some easy cheap mods on my truck, keep in mind i tow a lot and do a lot of highway driving and cant afford to loose mpg or blow up my truck, i dont want anything thats confusing or too difficlut untill i get more aware of the truck, so i want some power where i wont have to buy much and i can do at home without adjusting everything on the truck. i was thinking about a 3200 rpm spring, tewaking the pump, smoke screw, fuel pin etc... any ideas or comments would be greatly appreicated!! thanks
Old Mar 6, 2007 | 11:31 PM
rockjeep73's Avatar
I would start with the 3200 spring and turn the fuel pin to the deepest setting and see how you like that. If you want or need more then I would go to the full power screw. Keep the starwheel up and the smoke screw backed out and it will help save your fuel mileage.
Old Mar 7, 2007 | 09:03 AM
93beater's Avatar
ok ill give it a try this weekend, any one else have any comments or ideas???
Old Mar 7, 2007 | 08:01 PM
DODGE 92's Avatar
egt
before you do some mods especially if you pull
1ST THING GET A PYROMETER if you dont want to hurt the old girl
best 100$ youll ever spend
Old Mar 7, 2007 | 08:39 PM
Boatnik's Avatar
I agree. The first mod is Pyrometer. The stock configuration is safe. Anything else and you are flirting with a blown engine. A close friend and confident has a piston sitting on his desk at work as testimony to the wisdom. It melted.
bfrog4211
Jan 26, 2008 08:04 AM
JIT
Jan 20, 2008 06:41 PM
91TURBODIESEL
Oct 28, 2005 06:46 AM
GotBoost?
16
Jan 3, 2005 08:53 AM
greasy
Sep 7, 2004 06:40 PM
