Easy idle adjustment.
Old Mar 10, 2010 | 12:11 AM
Jim Lane's Avatar
Looks good, but I would recommend tapping for a fine thread bolt for a more precise adjustment.
Jim
Old Mar 10, 2010 | 01:32 AM
dstad's Avatar
Good job. I just made the same type of thing last week. Ill post up a pic
Old Mar 10, 2010 | 09:34 PM
getstucksome's Avatar
Jim
I didn't even think about that! If it ends up not being precise enough I'll just cut and tap some more steel lol
Old Sep 9, 2011 | 07:08 AM
BearKiller's Avatar
Originally Posted by Santaclaus
After looking over your design I just wondered about using one of the old high idle solenoids from the late 60s and early 70s gas burners. I don't remember for sure what they were call but they came on with the key so that the Indians would idle properly and then shut off and not diesel when you turned off the key.
Actually, a lot of the guys on the 1st Gen. Ford/diesel site have been doing that for several years.
They get the electric high-idle solenoid off of the older GM cars and have flip-a-switch idle control.
I am un-certain which GM cars have them; but, there are certain ones in particular that they prefer, as the solenoid mechanism itself is lock-screw-adjustable to dial in the exact hi-idle desired within the stroke limit of the device.
That's got me to thinking ; I need to put one on the wife's truck for cold mornings, maybe wired through a temperature switch for automatic operation, plus a switch that disables it when the shifter leaves PARK.
Old Sep 9, 2011 | 07:25 AM
BearKiller's Avatar
I think this is the route I will go on my idle adjustment.
A few improvements I intend are to use a Grade-8 FINE-thread bolt, maybe 1/4-28 which would pretty much match the thread-pitch of the factory screw.
I will reverse the direction of the bolt, such that the bolt's head is what contacts the throttle.
One more improvement will be a second threaded hole below the one pictured, with a bolt installed in the lower hole, with it's bolt-head on the forward side, such that I can adjust the head of the bolt to press against the timing-cover, thus bracing against the throttle-lever.
I will epoxy a wear-plate on the timing-cover where the brace-bolt contacts it.
What do you think ??
klx650a2
13
Jan 21, 2010 10:29 PM
goffracing
Feb 27, 2008 08:31 AM
crossy
Jul 13, 2005 03:45 PM
Den052
Jun 21, 2003 12:45 PM
Dusty 96
Nov 7, 2002 03:39 PM
