Easy high pressure piston lift pump question
I'm running a HP pump with a LP pump spring in it. Used to run a HP pump with a regulator when I had the big VE with a seal retainer on the truck. Switched to a LP spring when I changed it back to a stock pump when I was chasing an air leak I could never find.
Ok, so.............. I will need the spring, piston, and bronze sleeve to do it?
Bad news.........I called Cummins NW and they explained that no rebuild kits exist for the piston lift pumps. I asked about getting a replacement spring for the lift pump, no individual parts are physically available. So........ does anyone else know where I can get the low-pressure spring?
Too bad, no idea where to get just the spring.
I was disappointed to know that converting a HP to a LP lift pump was not an option. I'm not to fond of the idea that I have to buy a regulator and set fuel pressure. I also read someplace that boost needed to be compensated too.
