Drivers' side door hinges
Good morning gang:
My drivers' side door is sagging a bit and it is difficult to close the door tight. Anyone got a set of hinges? Are there any fixes besides R&R-ing the hinges?
Thanks.
Slate
Thanks.
Slate
I bought a new hinge from my Dodge Supplier, and swapped it out. I also bought a pin / bushing kit from Rock Auto, and rebuilt the old one. The old one now centers correctly (no slop) but the spring that controls opening & closing is still a little worn., which is no big deal.
If I had to do it over again, I'd just replace the pins and put it back together. If you are really good, you can just change them without removing the assembly. I removed mine as to assess, and clean the hinge. I just marked around the hinge with a marker, locating the hinges on the frame & door, so when I put it back together, it went quickly realigning it.
Pin kit is available just about anywhere. Dorman :703 272
Hinge part number from dodge: 4796259
joem
Apr 10, 2012 12:14 AM
mavrick211
May 29, 2006 08:09 PM
Dave88LX
May 15, 2006 08:44 AM
