Drivers Door Sagging....
Old Apr 15, 2006 | 10:18 AM
chuxtruk's Avatar
Question Drivers Door Sagging....
Not bad but sagging nonetheless and time for a new door hinge pin/bolt. Considering it's probably been opened/closed 3 times a day on average since being new, I'm not complaining either. Besides finding these things, any tricks for replacing these?? The one that's worn is the drivers side LOWER pin as you can see it moves when gently lifting the door by hand and is needing to be replaced. It doesn't look like a big job but one thing I've learned about working on my truck is that things SELDOM go as planned or look as easy as they do right at first. You guys think this would be a Dodge dealer part?? Anyways, as usual, thanks for your help!! Chuck
Old Apr 15, 2006 | 10:35 AM
old dog's Avatar
REALLY old dog
One thing to check is where bottum hinge attaches to door, they have a habit of getting metal fatigue, right at the back edge of the hinge. open your door and carfully watch the hinge and that area where it attaches to door,and if you see that it is broken or flexinf you can weld a plate in there to reinforce it. Had to do that to mine, 1992 club cab LE.
Good luck
Claude
Old Apr 15, 2006 | 11:12 AM
BC847's Avatar
1st Generation Admin
I think I've replaced my drivers door hinge twice now using OEM replacement hinges. If memory serves me correctly, Dodge is kinda proud of them ($).
I want to say Advance Auto or the likes may now have a pin/bushing kit to rebuild our hinges for much less money. It may not be labled for such, but there's a kit out there that will fit.
Old Apr 15, 2006 | 11:19 AM
Monty's Avatar
Going by what BC847 said, the hinge pin and bushing kit is made by the HELP! company and will be in that section at any auto parts store.
Old Apr 15, 2006 | 11:43 AM
rebal's Avatar
I got a kit from last year from NAPA ,it was like $6 for pins and bushings for the lower hinge and a couple hours to rebuild and realine the doors. do all 4 while the doors is off.
Old Apr 15, 2006 | 11:51 AM
BC847's Avatar
I think stock had hard plastic bushings where the kits we're talking about have bronze bushings.
Old Apr 15, 2006 | 01:28 PM
Yep, the Help! section at Advance is where I got my pin and bushing kit. I just replaced the lower, the upper was still in good shape. It's nice to have a helper to support the door while you have the pin out.
Old Apr 15, 2006 | 03:55 PM
PeytonMaterne's Avatar
I replaced mine recently as well, I got my pins/bushings at napa. One package does the upper and lower for one door. I found it easiest to drive the bottom pin out, and take the bolts out of the door at the top hinge (mark around the hinge at the top to help with realignment). If you remove the door from the truck, you can take it off by yourself but reinstalling it requires some help.
Old Apr 16, 2006 | 02:07 AM
chuxtruk's Avatar
THANKS you guys!! I never thought of replacing the whole hinge but that's an idea too. We'll see how it goes when I try the Help kit....any problems or hair pulling and I'm heading to the Dodge dealer!! Chuck
Old Apr 16, 2006 | 03:02 PM
RBergman's Avatar
a tdr member also buils some that should last a life time
http://www.turbodieselregister.com/f...d.php?t=132530
Old Apr 16, 2006 | 09:25 PM
PapeCAT's Avatar
yes terry was going to build a run of these super hinges but he cancelled due to lack of interest... he needs to run a minimum of 100 sets to get a vendor to go through with production... there are a lot of trucks out ther that need these hinges...
Old Apr 16, 2006 | 11:55 PM
RBergman's Avatar
actualy he is doing my left side ones now
and will do my right side ones when the
lefts are done
Old Apr 17, 2006 | 10:31 AM
kennedy's Avatar
What do they cost?
Old Apr 18, 2006 | 04:22 PM
chuxtruk's Avatar
Originally Posted by kennedy
What do they cost?
And does he still redo them?? Contact info? I'll check with Dodge and see how much they'll reem me for one, I'll let you know. My passenger side is just fine as it hasn't been used as much. It's that lower, drivers side hinge that's the problem.
Old Apr 18, 2006 | 11:38 PM
kennedy's Avatar
same problem here. I bought some new hinges from NewMoparParts.com They were about $30 a peice. I wonder if there is a way to modify them to get them beefed up.
