door locks not working
Old Jan 9, 2009 | 05:57 PM
vahillbilly's Avatar
Hi Ya'll
I recently purchased a 90 W250. It has power door locks.The power door locks do not work.
The door locks do not work. I cannot push the lock rod down manually and I cannot lock the truck with the key.
Any sugestions?
Thanks
Da Hillbilly from Va.
Old Jan 9, 2009 | 06:12 PM
HappyCamper's Avatar
Assuming that the locks are not frozen, but there is a mechanical issue.
You are going to have to pull the door panels and go through the linkages.
This was in the sticky
http://ramchargercentral.com/index.p...owtoshow;id=60
Take your time and clean things up and make sure that all the rod connetors are intact and working. Get the mechanical portions working then recheck the power locks. IF those continue to fail, then ir is either fuse, bad wiring or the solenoid (actuator) is dirty or gone bad.
staarma
0
Oct 25, 2007 12:49 PM
nomad65
Aug 20, 2007 06:01 PM
mkozlows
Mar 25, 2007 09:41 PM
AggiePhil
Feb 14, 2006 08:10 PM
Drafter
Jul 5, 2005 08:10 PM
