Diamond Eye Installs 2 outta 3 done
One Went on Well, one we had some Bend issues
We noticed Spring sag and motor mount sag Will make A Differences on Stock 4x4 , My truck is a standard which gives me more space to adjust and I have a 4 inch lift so i shouldn't see any clearance issues on the bottom
The autos seem to have a bit less wiggle room due to the Trans cooler
On the one truck he has even welded the Heat shield back on with room to spare
One more thing I phoned Diamond Eye and asked About a 4 inch option So we could use other turbos ... The guy to Talk to is mike and he will be Back on Friday I will be trying to get in touch with him to ask about it.
I installed the 4 inch with muffler in mine recently. It was kinda tight around the t case also but no interference. I used spacers around the pipe till I tightened it down and it stayed put. I also used band clamps on the joints. I had to fab up a piece for the stock bolt thru rubber mount at the bell housing and the rear most hanger but thats it. I would use this kit again.
The owner of the harder install is Still grinning. he is bolting up tonight So we will see if he has any problems
The Other guy Loves his lol He did it by him self so the hardest part was getting the down pipe lined up
i'm getting over the stack by about 2weeks now
its only better to blow smoke straight up than into the cars window that your passing.
My truck was never this messy with the he351 on it.
glass packs get a bad rep because of the rice rockets that love to throw them on their small 4 banger, which make them sound horrible.
does anybody know the dampening material used?
