Define o-rings in a head ???
Old Feb 5, 2008 | 08:52 PM
dieselcarpenter's Avatar
Question Define o-rings in a head ???
I have heard a lot about O-rings. I get that you have to have the head machined for circular grooves, but what for?
When do you need them?
Change in gaskets?
Could I get some definition?
Thanks guys!
D-C out!
Old Feb 5, 2008 | 09:02 PM
BC847's Avatar
1st Generation Admin
The O-ring groove is cut into the head, centered on the cylinder ring such that when a stainless wire is pressed into the groove, you've got about a .010" ring protrusion.
This pinches the standard head gasket's ring providing a tighter, stronger seal so as to better accommodate higher combustion pressures.
Old Feb 5, 2008 | 09:07 PM
bloodhound51's Avatar
a groove is milled in the cylinder head for the oring to sit in, while still inside the cylinder head gasket. orings are just more support for the cylinder head gasket. alot of different opinions on when you need them. i think any advanced timing coupled with more then factory boost results in premature head gasket wear. after two head gaskets and a bunch of fluids i bought 14 mm head studs for my engine and a marine head gasket.
Old Feb 5, 2008 | 09:57 PM
MikeThomas's Avatar
BC, is that your head?
Old Feb 5, 2008 | 10:00 PM
BC847's Avatar
Yup.
Old Feb 6, 2008 | 06:06 PM
Talking Thanks!!
Thanks guys, That cleared her right up!
I know this has been asked here already and I will search but I figure Ill ask any way.
Are there any places I can find who can mill the o-rings (on-line or can a local machine shop figure it out?)?, and are there any sources for re-man,new or "built heads" for my truck?
Old Feb 6, 2008 | 06:24 PM
Ilikebikes's Avatar
Originally Posted by BC847
Yup.
Gonna do any porting on that, David?
Old Feb 6, 2008 | 10:21 PM
mullishacrew's Avatar
i have a milling machine at my school and i also wanted to know what i can use or where can i get the orings for this? how deep should the ring be cut?
Old Feb 7, 2008 | 08:30 AM
BC847's Avatar
Yup, PDR worked it over such that it now presents with 195cfm intake, and 220cfm exhaust. That amounts to roughly a 34% increase on the intake and 44% on the exhaust over a stock 2nd gen head.
Still gotta get a 0.010" over stock head gasket and studs.
Old Feb 7, 2008 | 05:52 PM
CaptainChrysler's Avatar
That should really wake 'er up. Almost no matter what engine you are building, the power is in the cyl. head(s)
ahire
13
Oct 17, 2008 12:50 PM
BigErksG2
Sep 25, 2008 06:43 PM
12VRoush
Oct 15, 2007 08:00 PM
1320
Mar 8, 2005 08:56 PM
