DDP Stage 1, 2 & 3 Inj. Nozzles
Old Jan 27, 2010 | 04:50 PM
jimbo486's Avatar
has anyone noticed these before? i just happened to be browsing DDP's website and came across the 3 stages of nozzles.
http://www.dynomitediesel.com/prod_d...irst+Gen/0.php
they claim stage 1's will add 50rwhp, stage 2's will add 75rwhp and the stage 3's will add 100rwhp. they don't list sizes at all such as how many orifices and how large each orifice is. seems like if they're good, it'd be good upgrades for those looking to add power on a smaller budget. reasonably priced at $299 for stage 1, $349 for stage 2 and $399 for stage 3. all it would take is basically a rebuild to install the nozzles and having the pop pressure set at 245 bar.
Old Jan 27, 2010 | 05:29 PM
Richie O's Avatar
366 Spring Chicken
I bet a shop would charge 60 bucks a stick to convert tips and set pop pressure. So you would have another 360 just for the shop work.
Old Jan 27, 2010 | 05:35 PM
jimbo486's Avatar
probably worth a try calling a local shop first and asking what they would charge for that. not doubting you're thoughts though. maybe changing out the nozzles would be a DIY task if you know you're injectors are already set at 245? i'd like to know dimensions of the nozzles first and foremost.
Old Jan 27, 2010 | 07:23 PM
The_Head's Avatar
They are a relatively new addition to the website. Like 1-2 months ago.
Old Jan 27, 2010 | 10:07 PM
schamran's Avatar
How much do they charge to test injectors? I would like to know about this because I think mine are causing a hard cold start problem.
Old Jan 28, 2010 | 12:48 AM
Crazy Matt's Avatar
I seen tha few weeks ago and priced em abit cheaper. I'll prolly buy a set of nozzles after I put the piston pump in. I did find guinea pig for the 100hp nozzles -Benjamin b2
I guess I'll be pop testing again.
Old Jan 28, 2010 | 01:47 AM
Benjamin b2's Avatar
soon as i sell that exhaust brake and my hx i will be your "Guinea Pig".
Old Jan 28, 2010 | 01:53 AM
Crazy Matt's Avatar
I might have a turbo in the works to sucker ya into.........
.............Im not to be held responsible for getrag breakage........
Old Jan 28, 2010 | 02:36 AM
95ram's Avatar
Swap'n out the tips is pretty easy. IIRC getting the pop test isn't all that expensive.
Old Jan 28, 2010 | 08:44 AM
soggy's Avatar
I got mine reset for around 50 bucks IIRC. The pump shop just did it by thr hour.
Old Jan 28, 2010 | 12:07 PM
jimbo486's Avatar
a shop out near me tested mine for free. of course 4 of the 6 were bad so that's where they made their money
Old Jan 28, 2010 | 01:27 PM
part of being the test dummy, he is going to reset my pop presures for free, and im going to make sure he knows this.
Old Jan 28, 2010 | 08:08 PM
dzl_damon's Avatar
I assume the stage III's are like the DDP3s? 55 litres per hour flow rate?
Old Jan 29, 2010 | 02:11 AM
Crazy Matt's Avatar
Then I getta call you dummay for now on
SKATERHAULER
Mar 9, 2012 03:15 PM
DisplacedOkie
Jan 27, 2009 02:05 PM
ramtd02
Apr 19, 2007 06:16 PM
relay93
Mar 13, 2007 11:25 PM
9 sec camaro
20
Aug 26, 2006 01:30 PM
