Dana 80 Installed pictures
Old Nov 27, 2009 | 08:45 PM
roxxx's Avatar
http://dkorp.ca/dodge/Dana%2080%20Mod
the only picture i didnt get ... forgot was of the e brake mount
Old Nov 27, 2009 | 09:59 PM
Swarthy Dago's Avatar
looks clean good job, what would you do to replace the stud bolt if it bends, looks like you can't get into that tube stock ?
Old Nov 27, 2009 | 10:07 PM
NO_SPRK's Avatar
Looks good. I like your shock mounts. What did you do about the perch width difference?
Old Nov 27, 2009 | 10:46 PM
roxxx's Avatar
Are you talking the u bolts ? If so optical illusion and bad camera angle they are seprate from the shock perches the Dana 80 mount brackets were used they are stock
If you are talking about the Axle tube them self ? I will have bigger problems if i bend the Tube stock
Old Nov 27, 2009 | 10:50 PM
roxxx's Avatar
(43 and some cant remember )
the spring perches were the same as the Dana 70 and as far as the shock perches they are the same as the Dana 70 mounts to the only difrentce is the Dana 80 is a bit wider Drive wise very stable even with out the sway bar which i never had but hope to soon
tankeryanker
14
Jan 19, 2005 04:18 PM
Mechanos
Jan 22, 2004 12:45 PM
matthopp
Nov 21, 2003 04:49 PM
mcevins
Jul 3, 2003 02:06 AM
Stamey
Apr 18, 2003 10:34 PM
