D70 Dually Disc Brake Kit
Anyone used these folks or anyone else for a dually D70 disc brake conversion? Says for use on the 70HD under the Chebbys, but surely they didn't change them up too much huh?
http://diy4x.com/cart/index.php?rout...&product_id=50
here's another one, just way more money and i'm under the impression that it was made for the 94+ tho they assure me that it'll work on the 93 down
http://www.blackbirdscustomtrucks.co...0.html#8dually
Ideas, opinions?
Thanks,
James
Ideas, opinions?
Thanks,
James
Thanks,
James
The OP is asking if this kit will work on his dually... I asked so he didn't purchase the kit with mis-information to his question.
The D80's from a dually can have disc brakes, but they look like they have dually extensions similar to the front differential to clear the inner dual or something weird looking. I'm afraid there are not any disc brake options for a D70 dually. I'm pretty sure it all has to do with the inner dually wheel not clearing the caliper/rotor. If you do find a source, let us know, but I can't see how it's going to work on this type of axle.
dzl, the kits i posted are both for dually applications, was seeing if anyone had any experience w/ either company or kit. If not once i get back in the states i plan on ordering one and i'll do a write up on it i suppose
James
James
Nope, I'm good. Just letting the original poster know that since it worked well for a single wheel truck, that it did not mean it would work for his dual rear wheel truck. I saw your signature and noted you had a W250, so I asked for clarification. Chill, all in good faith of helping each other out.
The whole thing with a dually axle is the increased distance between the hub, and the backing plate flange. Essentially, the drum is deeper and more tapered for the extra inboard offset on the dually wheel.
One solution is to use something like a Savana/Express 3500 dually rear rotor. Its very deep (over 5") which puts your caliper far enough inboard to clear the dually wheel. Then get a generic caliper bracket and find a way to mount it to the existing backing plate flange.
I constantly wonder why the Dana 80 in my grandpa's '02 DRW has discs with 16" wheels. Yet, it's always said about our Dana 70s that 16" wheels won't clear the calipers.
That being said, aren't hubs/wheel-ends interchangeable between Dana 80 and 70 axles??
Easy. Its because the rotor and caliper are far enough inboard to clear. The dually hub flange on the disc brake Dodge is about 3" thick. I'll try to get a pic of my E350 DRW disc arrangment - same idea.
ok, so in doing a little more research i found this:
http://ramchargercentral.com/miscell...ersion-145419/
looks doable w/ diy's brackets for a dually chebby. i'm defintley gonna give this a try when i get home and will let ya'll know the results. unless someone wants to give it a shot before i get to it lol
James
James
James
James
