d350 4wd conversion ?
Its been awhile since i posted but i still read from time to time. i have a question about converting my 1992 d350 5speed to 4wd. I have found a 1990 w250 cummins it is auto and has 118,000 miles on it, regular cab long bed. Can i do the conversion with the w250 as a parts truck? do i have to get a new 4wd transmission or just a tail shaft and tail housing on my transmission. I am going to keep it 5speed.
Thanks
Ryan
Thanks
Ryan
Thanks
Ryan
Thanks
Ryan
the tail housing on a 4x4 has to let the bigger coupler (29 spline) in, also you need the next piece sometimes called an adapter: it also serves as a mount. Additionally, that piece has the proper setup for the 3 holes to bolt on the transfer case linkage ( on an auto the 3 holes are spaced differently)
If you modify the auto NP205, get gasket and seal kits, as well as the roller bearings: it is time consuming but not that difficult
your speedometer will work off of the transfer case: check that it is for the gear ratio/wheel size you have
a few switches: neutral safety and backing lights should be the same, if you want some sort of light indicator on the dash that 4 wheel drive is engaged you might have to come up w/ sthg
if you drop the tranny to see how everything bolts up before installing, check your rear main seal, your throwout bearing, clutch and all.
all I can think of...
Truck For Sale 1985/1993 Dodge D350 Cummins CREW CAB with 4x4 conversion
fratzog
1st Gen All Products
0
May 10, 2015 09:42 PM
VIN#Diesel
Jun 20, 2011 07:25 PM
95black2615
Dec 20, 2006 06:37 PM
1320
May 6, 2003 06:30 PM
