cummins/GM auto adaptor[frito-lay)
Old Oct 23, 2007 | 02:28 PM
stock600's Avatar
Cool cummins/GM auto adaptor[frito-lay)
does any one have this adaptor for sell or is it off to the truck junk yards, i understand all frito -lay trucks came with 4 or 6 bt engines with TH350 or even 400s. i need the engine adaptor for a project. thanks ryan
Old Oct 23, 2007 | 02:45 PM
Mattster's Avatar
I've seen them on Ebay periodically when I was looking for a 4bt for a project but never got one.
Heres one on ebay bit pricey:
http://cgi.ebay.com/ebaymotors/CUMMI...spagenameZWD1V
Old Oct 23, 2007 | 03:18 PM
stock600's Avatar
man i thank you for the reply 475.oo doesnt sound to bad to me are they pretty common could it be bought from cummins or GM for less than a million dollars, or is this just a frito lay deal? if i can get the parts together im wanting to build a datsun 260Z drag car with the 5.9 and TH350 the car has a 327 now, cool huh. runs 8.2s in the 1/8 id think i could regear and run that or better with my 93 12 valve .... i know it has a v.e. ..... so
Old Oct 23, 2007 | 03:26 PM
CaptainChrysler's Avatar
I researched this idea awhile ago and decided an aftermarket setup might be the way to go.
Here's one. http://www.transmissioncenter.org/cu...bt_adapter.htm
3910516 is the cummins part# for the adapter only. I checked and it had been superceeded. Was like $700.
Major drawbacks: puts the engine (or tranny) and a 10* angle, and the auto version flywheel will not hold much power.
Anyways don't let me discourage you, just my 2 cents.
Old Oct 23, 2007 | 03:39 PM
stock600's Avatar
the car with 327/350 setup wieghs 3050 runs 8.2 on the motor 7.5 on 175 shot,4.56 gears with 28" tires, i was thinking a 3.00 gear with the 28.s and 2800 rs would allow for around 80-82 mph if this isnt enough [gear bound] then i could do the gov. spring deal and get what? 3200-3400 or maybe more this i know would be more than enough 110+ mph ol 12 valve v.e. pump motor want do that huh, ive got a new sitzer 300 turbo i will put on and also new injectors 40 or 60 hp dont remember but their new. and will learn the tricks to turn up the pump and bump the timing what do yall think, the turbo was on my 02 24 valve and was a huge improvment over the stock HX 35 W my 93 is what a hy 21 or 27 right ? i looks small but with at least a 18 cm turbine its huge a very lagy. any other opinions thanks all , ryan
Old Oct 23, 2007 | 04:28 PM
stock600's Avatar
thanks for the response this is prob. a much better idea what was or is your project im contacting that company now to price this parts ,thanks ryan
Old Oct 23, 2007 | 04:50 PM
stock600's Avatar
is it a big deal to make her spin 3200-3400 i was told is would cost 10 dollars and my time couple hours any one done it? i think it will be ness. as i feel it will run faster than 82 in the 1/8 mile heck a turned up motor in the stock 6500+ lbs truck can run that ill be half that wieght. caint hardly wait. any ideas?
Old Oct 23, 2007 | 05:07 PM
Well I am not sure about a VE for sure, but the p pump guys run a 4K Governor all the time. I have been told you need a good harmonic dampener with it. There are bad harmonics at 4100 . I have the 3200 spring and it pulls real good. Will spin to 3500 with light load, but lays down after 3200 when pulling.
Old Oct 23, 2007 | 05:29 PM
stock600's Avatar
thanks my math says at 3200 with a 3.00 gear and 28" tire is 89 mph, im sure it will be cutting it close if it dont go gear bound before i bet its soon after , but thats o.k. long as im under power for 660 feet!!!!! thanks do wish they made a 3400 to be sure though.
Old Oct 23, 2007 | 07:43 PM
stock600's Avatar
ive heard some talk of a 3400 spring any one know the part # or anything about it . thanks
Old Oct 23, 2007 | 08:12 PM
rbrettctd's Avatar
They make a 4200, not sure of a part number, but piers has them...BTW, HOW are you going to fit a 5.9 in a 260z? Thatd be crazy, but tight for sure. Id like to see this done, as it would be wickedly fast.
Old Oct 24, 2007 | 10:18 AM
stock600's Avatar
oh it will fit ive measured and remessured the narrowed cummins with the pretty flat oil pan will work out fine for me only thing tight is turbo i was thinking a 3rd gen manifold to aim the t. down rather than straight out, they all interchange right , will the super b bolt to the 3rd gen? wont be using on intercooler either if temps are a concern ill put a snow kit on it , itd be good for power to remember only 660'. thanks ryan
Old Oct 24, 2007 | 07:43 PM
stock600's Avatar
any one else put a cummins in something odd, besides all the extra wieght its got to be one of the coolest engines to do this with, im ordering the parts after market easier and stronger and a lot more money! THE SWAP SHOULD TAKE ME TOO LONG being its a race ready car that i use every other weekend. wish it was the next year motor with the P pump but its not well see what this little ve pump is all about i know very little about this pumps power output , i want to spent money smartly in the right places, already have S300 turbo, and like marine inj. bought to put on the now stock engine with only 80 something thousand miles not muck for an 93 huh. s300 uses a 4" down pipe that will soon be prob. a 8-10" uppipe. can you see it !
Old Oct 24, 2007 | 11:36 PM
1stGen545's Avatar
Piers part # PRD20113540 is for the 4200RPM spring kit $25
Old Oct 25, 2007 | 12:23 AM
stock600's Avatar
545 thanks is this for the ve pump correct not a p- pump, my math says at 4200 and my setup itd be good for 112mph heck i could run the quarter then, someone mentined bad harmonics at 4100 know any more about this, i guess new valve springs are a must too, are they with the 3200 that it seems everone else uses? thanks for the part number by the way
