Cummins Crew Cab Resto Mod Build
Very interested in this build... I´m in the middle of a restoration as well... Everything is down to nuts and bolts. There won´t be an untouched piece left... I really like the stance and demeanor of the truck with the aftermarket wheels and tires before disassembly for paint... Nice work.
I didn't actually measure before and after, but it sits level with the 6" I have up front. I also aftermarket spring perches in the rear that may give me a little more lift than what the stock Dana 60 had as well, plus the axle tubes are larger on the AAM 11.5 rear axle I have under there as well.
Truly a superior build
Attention to detail is there, as is quality of construction, and some pretty good parts for what this truck is.
Good work!
I have one going on as well...different take than this truck though.
Good work!
This build started out as more of a tow rig/drive to the local burger joint in town but it's now pointed in the direction of being a expedition rig. I've got a lot of mods planned to make it a more capable offroader, but it will never be a dedicated trail rig/rockcrawler.
I've read your build on the duramax forum and I like quite a few of the mods you have done, some are definitely unique.
Thanks for the compliments.
The Dodge truck build on D-max forums continues. currently installing the front dana 60 with locker/big axles, hubs and the engine and trans which got the full treatments.
Again, top notch workmanship on your project!
tacoAGGIE
Nov 8, 2013 08:56 PM
